ESP light on - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Community > JK General Discussion
Old 03-27-2010, 07:34 PM   #1
voodoojk
voodoojk's Avatar
Member # 581
ESP light on
I was driving down a dirt road today and all of a sudden my traction control and my ESP lights are illuminated on my dash. Great.. I checked the sensor and wires, nothing unplugged. I un hooked the battery, no luck. I pulled the fuse - jeep wont start without the ESP fuse FYI. lol. There are no codes showing.
Any clues??? I think it might be my clock spring. but... who knows.
__________________
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
Tom Woods Shafts F&R
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Buschwacker Flat Flares
Poly Tie Rod
JKS Disco
voodoojk is offline   Reply With Quote Quick reply to this message
Old 03-27-2010, 07:51 PM   #2
jeeperjkj
jeeperjkj's Avatar
Member # 4516
Is your steering wheel centered?
Have you done any mods to it lately?
__________________
jeeperjkj is offline   Reply With Quote Quick reply to this message
Old 03-27-2010, 07:56 PM   #3
voodoojk
voodoojk's Avatar
Member # 581
steering wheel is the same for months now. I put new steering stabilizer on last week but have driven all over with no problems.
The light is permently illuminated. Not just coming on at random. Even sitting still on my garage...its on.
__________________
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Poly Tie Rod
JKS Disco
Old 03-28-2010, 09:56 AM   #4
seer
seer's Avatar
Member # 822
If it's on all the time, it's probably the electronic/electrical side. Check all the wires you can see going to the sensors. If those all look good, you may need to take it in. If you haven't done anything to cause the steering wheel to spin around foolishly (like disconnect the pitman arm) then it's probably not the clockspring.
__________________
BEER Helping me do stupid things to my JK since 2007!
seer is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 11:30 AM   #5
tkob1060
tkob1060's Avatar
Member # 5021
if the brakes are suddenly applying with the light on it should throw a code for one of the wheel sensors. You can pull the J6 fuse and it will leave the abs and esp completely disabled, I ran without mine for a couple weeks when my sensor and hub was bad.
here is diagram of the fuses
http://www.jkowners.com/forum/showthread.php?t=22584
what fuse did you pull that caused the Jeep not to start?
__________________
tkob1060 is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 02:02 PM   #6
voodoojk
voodoojk's Avatar
Member # 581
i pulled the M37 fuse that controls ABS, ESP and the fuel pump high control..it wont work after you pull that fuse because of the fuel pump part of it i guess.
After driving 50 miles last night i went into a move and 3 hours later came out and the light was gone. Then this morning no light until about 10 feet down the road. light came on again, then a chime and a p0627 code wich is a fuel issue. idk wtf is going on.
__________________
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Poly Tie Rod
JKS Disco
Old 03-28-2010, 02:36 PM   #7
rooster
rooster's Avatar
Member # 1690
I pulled my axles a couple weeks ago to install the Rock Krawler lift and mine is doing the exact same thing. Im throwing wheel sensor codes, high amp to the fog light codes and fuel issue codes. Even had a gas cap code. Its still doing it and I have no idea.
rooster is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 03:47 PM   #8
Jeep School
Jeep School's Avatar
Member # 4485
You say the steering wheel is the same, but not whether or not it is straight. If it's not perfectly straight, adjust your drag link. Also, check your tire pressure--just 3 psi difference in your front tires could cause it.
__________________
Nena Barlow
-- downloadable maps & trailbooks
Jeep School is offline   Reply With Quote Quick reply to this message
Old 03-30-2010, 05:22 PM   #9
voodoojk
voodoojk's Avatar
Member # 581
Working for a VW dealer..our Routans are chrysler T&C's so we have a star scan tool. PUlled a code C123F - Steering angle sensor. Its my CLock Spring.
__________________
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Poly Tie Rod
JKS Disco
Old 03-30-2010, 05:42 PM   #10
seer
seer's Avatar
Member # 822
Did you mess with your steering wheel/pitman arm/something earlier?
__________________
Old 03-31-2010, 12:23 AM   #11
voodoojk
voodoojk's Avatar
Member # 581
nope...not at all. But we get the Routans in all the time with ESP lights on and its the clock spring. Same part thats in the JK. We replaced at least 4 this year in the vans.
__________________
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Poly Tie Rod
JKS Disco
Old 03-31-2010, 12:31 AM   #12
GOWREVER
GOWREVER's Avatar
Member # 3819
I just replaced my clock spring and none of my lights turned off. Well the airbag light. I've got the same lights on and it's almost time for the cheap electrical tape fix...
__________________
"Dude, did you see that Green Jeep out in the parking lot?"
"Yeah, its' mine..."
GOWREVER is offline   Reply With Quote Quick reply to this message
Old 03-31-2010, 08:03 AM   #13
seer
seer's Avatar
Member # 822
How far have you driven it since replacing it?
__________________
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
