Dynatrac ProSteer Ball Joints and RCV Axle Shafts? - JKowners.com : Jeep Wrangler JK Forum
Old 03-08-2010, 11:01 AM   #1
gt3073b
gt3073b's Avatar
Member # 107
Do the Dynatrac ProSteer joints interfere with the RCV axle shafts? It appears that the orange boot is bigger than the ears on the factory axle shafts since it doesn't fit through the knuckle. The ProSteer joints are grease-able, which means there is a grease fitting somewhere on the lower joint that would be inside the inner C.
I'd hate to spend the $$$ on ProSteer joints and lock myself out of getting the RCV shafts later on.
Thanks,
Bryan.
__________________
2007 JK Rubicon Unlimited Rescue Green 6 Speed
Mods Shrockworks Rails & Bumpers, Currie Lift, Tom Woods 1310/1350, 36-13.50 Bias Iroks on HMMWV 12 Bolts (play tires), 35" Toyo M/Ts on ProComp 7028s
In Progress
To Do Co4Lo suggested Grade Eleventy bolts for my new bumper flag mounting bracket
gt3073b is offline   Reply With Quote Quick reply to this message
Old 03-08-2010, 12:10 PM   #2
muddpuppy01
muddpuppy01's Avatar
Member # 5483
Not if the grease fittings are on the non threaded side of the joint like normal greasable joints
muddpuppy01 is offline   Reply With Quote Quick reply to this message
Old 03-08-2010, 01:56 PM   #3
gt3073b
gt3073b's Avatar
Member # 107
The non-threaded (cup) portion of the lower ball joint is right below the axle. That is where my concern is.
__________________
In Progress
Old 03-08-2010, 03:25 PM   #4
usmcdoc14
Fistfull of Boomstick
usmcdoc14's Avatar
Member # 206
I will let you know as soon as I do the install. hopefully this week.
__________________
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 03-08-2010, 05:24 PM   #5
seer
seer's Avatar
Member # 822
D'your ball joints show up already?
__________________
BEER Helping me do stupid things to my JK since 2007!
seer is offline   Reply With Quote Quick reply to this message
Old 03-08-2010, 06:17 PM   #6
usmcdoc14
usmcdoc14's Avatar
Member # 206
I don't know I am not at home and my wife has no clue what is the diffrent metal things in boxes that have come in.
and I need to buy a new ball joint press.
__________________
Old 03-08-2010, 06:27 PM   #7
andrelopez99
andrelopez99's Avatar
Member # 5329
May I asked when you ordered your ball joints, cause it's been more than six weeks...
__________________
andrelopez99 is offline   Reply With Quote Quick reply to this message
Old 03-08-2010, 06:57 PM   #8
seer
seer's Avatar
Member # 822
Dammit!
__________________
Old 03-08-2010, 10:02 PM   #9
gt3073b
gt3073b's Avatar
Member # 107
Thanks! I'm holding off on putting my new tires on until I get new ball joints in. The local shop said they couldn't get a good read on the alignment because the ball joints were too sloppy. I got 110,000 miles out of the first set of tires and ball joints, but I have some weird wear patterns that probably mean the joints have been getting loose for some time.
Thanks again,
Bryan.
__________________
In Progress
Old 03-09-2010, 12:45 AM   #10
s10x1000
s10x1000's Avatar
Member # 3671
110,000's a hell of a good run
__________________
s10x1000 is offline   Reply With Quote Quick reply to this message
Old 03-09-2010, 08:08 AM   #11
Dynatrac
Dynatrac's Avatar
Member # 7964
We're still trying to confirm that we have clearance for the ProSteer Joint and the RCV shafts. We THINK it's OK but we're waiting on info from RCV.
We've received a partial shipment of our ProSteer ball joints and will be shipping product late this week.
Dynatrac is offline   Reply With Quote Quick reply to this message
Old 03-09-2010, 09:15 AM   #12
chromedome
chromedome's Avatar
Member # 762
I've got RCV's on my '08 Rubicon 4dr. I'd be happy to bring it by for a test fit.
I'm in Tustin. Let's make a deal! PM me!
chromedome is offline   Reply With Quote Quick reply to this message
Old 03-09-2010, 11:09 AM   #13
Dynatrac
Dynatrac's Avatar
Member # 7964
We appreciate your offer but we should be good.
Old 03-09-2010, 06:39 PM   #14
gt3073b
gt3073b's Avatar
Member # 107
I will order a set as soon as you get it confirmed.
Bryan.
__________________
In Progress
Old 03-11-2010, 12:11 PM   #15
Dynatrac
Dynatrac's Avatar
Member # 7964
We've got an axle coming in from RCV to allow us the check clearances. The RCV axle has larger diameter at the ball joint than a standard Rubi u-joint. The drawings we received didn't provide enough information to confirm clearance. We should have the info we need Monday or Tuesday.
Old 03-11-2010, 04:05 PM   #16
usmcdoc14
usmcdoc14's Avatar
Member # 206
same goes with the write-up as mine are on hold untill the fitment is confirmed
__________________
Old 03-11-2010, 04:24 PM   #17
maverick
maverick's Avatar
Member # 669
Scott (DIAMOND OFFROAD) is installing sleeves, gussets, truss, PSC assist, RCVs, and ProSteer Balljoints (as soon as he receives them). You may want to get on the phone with him.
Bart
__________________
maverick is offline   Reply With Quote Quick reply to this message
Old 03-12-2010, 08:06 AM   #18
TheMike
TheMike's Avatar
Member # 5472
I run the RCV's and are having my Prosteer's next day aired to me by Dave at Northridge so that I can put them in Wed. According to him I found out that the Prosteer's are 3/32 taller. I put 3/32 worth of feeler gauges on top of my stock bottom joint and there's VERY little room left. There is clearance and light can get through but it's close.
A couple of thoughts: How close is too close? If they do end up rubbing (dirt/flex whatever), will the boot sort of self trim? It would appear that a little less boot would be ok but then again.....
I know that Dynatrac will know soon enough (what's the quickest way to find out the result?). Just thought I would throw my input out there.
__________________
Black 2007 JK Rubicon Unlimited: 6.1 BOR Hemi, AEV: bumpers, Pinters, 4.5" lift. 5:13's, New Kevlar 37" MT/R, Chromo Rear Shafts, Front: RCV Shafts, gussetted, sleeved etc etc etc (should have just bought a prorock!), all RED badged
2007 Adventure Trailer,
#71
TheMike is offline   Reply With Quote Quick reply to this message
Old 03-12-2010, 08:12 AM   #19
chromedome
chromedome's Avatar
Member # 762
The quickest way would have been for Dynatrac to accept my offer and let me drive over there (ten minutes away) and test fit them earlier this week. You'd know for sure right now! But sadly they declined.
Old 03-12-2010, 09:28 AM   #20
maverick
maverick's Avatar
Member # 669
3/32 taller?? Looking at the pic... it that overall length... i.e. that includes the grease zert? If so, can't it be swapped out with a low-profile zert similar to what is used on CTM u-joints?
__________________
Old 03-12-2010, 09:48 AM   #21
Dynatrac
Dynatrac's Avatar
Member # 7964
The pictures on our site show Dodge and Ford ProSteer joints. The JK joint has the zerk on the side so it won't cause an issue.
We have an axle assembly in-house with ProSteers that is being prepped for our rig that will be heading to Easter Safari. Our test axle will be checked in that housing ASAP.
I'll post results up here immediately.
Old 03-12-2010, 09:52 AM   #22
TheMike
TheMike's Avatar
Member # 5472
Awesome. I eagerly look forward to your report. Thanks for the speedy response as it's a bit time critical at this point.
__________________
#71
Old 03-12-2010, 10:22 AM   #23
maverick
maverick's Avatar
Member # 669
Thanks! See you at EJS!
__________________
Old 03-12-2010, 04:02 PM   #24
Dynatrac
Dynatrac's Avatar
Member # 7964
The verdict is in and it's......maybe
The test unit we measured would not touch the ball joint but it was incredibly close. We can see that with the tolerences that are allowed with the various components that it is possible that some will contact with the ball joint. Since the ball joint end is relatively smooth and the boot is fairly thick, I would guess that the boot would self clearance. Certainly not ideal but not terrible either.
Gil will be installing a set of these on his JK very soon and should be able to provide you with 'real world' feedback and his opinion on the clearance.
I'm sorry I couldn't provide a more definitive answer.
Scott
Old 03-12-2010, 04:06 PM   #25
Alaska-HWY JK
Member # 260
Clearance.
Thanks for the info.
Alaska-HWY JK is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
