Jeep JK 2009 Fuse Box Map Layout Diagram - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Electrical & Lighting Tech Dept.
Old 02-01-2010, 07:59 AM   #1
RobertK
Member # 4727
Repost of earlier thread with minor corrections noted:
M1 is 15 Amp Blue, not Yellow
Circuit Breaker nomenclature is CB1, not C81
Since the fuse layout map on the inside cover of the fuse box is tough to read for those of us with older eyes, and since there have been several threads requesting such a diagram, I thought I'd go ahead and post this for whoever finds it useful.
See attached image below... I've also included the fuse listing from the owner's manual for convenience.
If anyone sees any mistakes, let me know immediately and I'll fix it. Note that this is from my 2-door JK 2009... I don't know if there are any differences between the 2-door and the 4-door, nor if there were any changes between 2007 or 2008.
Cavity
Cartridge Fuse
Mini Fuse
Description
J1
40 Amp Green
Power Folding Seat
J2
30 Amp Pink
Transfer Case/Pwr Liftgate Module
J3
40 Amp Green
Rear Door Module (RR DOOR NODE)
J4
25 Amp Natural
Driver Door Node
J5
25 Amp Natural
Passenger Door Node
J6
40 Amp Green
Anti-Lock Brake System (ABS) Pump/ESP
J7
30 Amp Pink
Anti-Lock Brake System (ABS) Valve/ESP
J8
40 Amp Green
Power Memory Seat (If Equipped)
J9
40 Amp Green
PZEV Motor/Flex Fuel
J10
30 Amp Pink
Headlamp Wash Relay/Manual Tuning Valve
J11
30 Amp Pink
Sway Bar/THATCHAM Lock-Unlock/Power Sliding Door Module
J13
60 Amp Yellow
Ignition Off Draw (IOD) — Main
J14
40 Amp Green
EBL (Rear Window Defogger)
J15
30 Amp Pink
Rear Blower
J17
40 Amp Green
Starter Solenoid
J18
20 Amp Yellow
Powertrain Control Module (PCM) Trans Range
J19
60 Amp Yellow
Radiator Fan
J20
30 Amp Pink
Front Wiper LO/HI
J21
20 Amp Yellow
Front/Rear Washer
J22
25 Amp Natural
Sunroof Module
M1
15 Amp Blue
Center High Mounted Stop Light (CHMSL)/Brake Switch
M2
20 Amp Yellow
Trailer Lighting
M3
20 Amp Yellow
Frt/Rear Axle Lockers
M4
10 Amp Red
Trailer Tow
M5
25 Amp Natural
Inverter
M6
20 Amp Yellow
Power Outlet #1/Rain Sensor
M7
20 Amp Yellow
Power Outlet #2 (BATT/ACC SELECT)
M8
20 Amp Yellow
Front Heated Seat
M9
20 Amp Yellow
Rear Heated Seat (If Equipped)
M10
20 Amp Yellow
Ignition Off Draw — Vehicle Entertainment System (IOD-VES), Satellite Digital Audio Receiver (SDARS), DVD, Hands Free Module (HFM), RADIO, Antenna (ANT), Universal Garage Door Opener (UGDO), Vanity Lamp (VANITY LP)
M11
10 Amp Red
(Ignition Off Draw) IOD-HVAC/ATC, MW SENSR, Underhood Lamp (UH LMP)
M12
30 Amp Green
Amplifier (AMP)
M13
20 Amp Yellow
Ignition Off Draw— Cabin Compartment Node (IOD-CCN), Wireless Control Module (WCM), SIREN, Clock Module (CLK MOD), Multi-Function Control Switch (MULTIFCTN SW)
M14
20 Amp Yellow
Trailer Tow (Export Only)
M15
20 Amp Yellow
COL MOD, IR SNS, Heater Ventilation, Air Conditioning/Automatic Temperature Control (HVAC/ATC), Rear View Mirror (RR VW MIR), Cabin Compartment Node (CCN), Transfer Case Switch (T-CASE SW), RUN/ST, Multi-Function Control Switch (MULTIFTCN SW), Tire Pressure Monitor (TPM), Glow Plug Module (GLW PLG MOD) — Export Diesel Only
M16
10 Amp Red
Occupant Restraint Controller/Occupant Classification Module (ORC/OCM)
M17
15 Amp Blue
Left Tail/License/Park Lamp (LT-TAIL/LIC/PRK LMP)
M18
15 Amp Blue
Right Tail/Park/Run Lamp (RT-TAIL/PRK/RUN LMP)
M19
25 Amp Natural
Auto Shut Down (ASD #1 and #2)
M20
15 Amp Blue
Cabin Compartment Node Interior Light (CCN INT LIGHT), Switch Bank (SW BANK), Steering Control Module (SCM)
M21
20 Amp Yellow
Auto Shut Down (ASD #3)
M22
10 Amp Red
Right Horn (RT HORN (HI/LOW)
M23
10 Amp Red
Left Horn (LT HORN (HI/LOW)
M24
25 Amp Natural
Rear Wiper (REAR WIPER)
M25
20 Amp Yellow
Fuel Pump (FUEL PUMP), Diesel Lift Pump (DSL LIFT PUMP) — Export Only
M26
10 Amp Red
Power Mirror Switch (PWR MIRR SW), Driver Window Switch (DRVR WIND SW)
M27
10 Amp Red
Ignition Switch (IGN SW), Window Module (WIN MOD)
M28
10 Amp Red
Next Generation Controller (NGC), Transmission Feed (TRANS FEED), J1962
M29
10 Amp Red
Occupant Classification Module (OCM)
M30
15 Amp Blue
Rear Wiper Module (RR WIPER MOD), Power Folding Mirror (PWR FOLD MIR)
M31
20 Amp Yellow
Back-Up Lamps (B/U LAMPS)
M32
10 Amp Red
Occupant Restraint Controller (ORC), TT EUROPE
M33
10 Amp Red
Next Generation Controller (NGC), Global Powertrain Engine Controller (GPEC)
M34
10 Amp Red
Park Assist (PRK ASST), Heater Ventilation, Air Conditioning Module (HVAC MOD), Headlamp Wash (HDLP WASH), Compass (COMPAS)
M35
10 Amp Red
Heated Mirrors
M36
20 Amp Yellow
Power Outlet #3 (BATT)
M37
10 Amp Red
Anti-Lock Brake System (ABS) , Electronic Stability Program (ESP), Stop Lamp Switch (STP LP SW), Fuel Pump Rly Hi Control
M38
25 Amp Natural
Lock/Unlock Motors (LOCK/UNLOCK MTRS)
RobertK is offline   Reply With Quote Quick reply to this message
Old 02-27-2010, 12:11 PM   #2
Dancin Dan
Member # 3812
Awesome. Exactly what I was looking for!
This should be a sticky
Dancin Dan is offline   Reply With Quote Quick reply to this message
Old 03-07-2010, 09:02 PM   #3
Rob_A
Member # 8264
Sticky x2
Rob_A is offline   Reply With Quote Quick reply to this message
Old 03-08-2010, 10:32 AM   #4
Stickdude
Member # 5380
Nice job. I'll check this out against my 07 2 dr and post if there are differences.
Stickdude is offline   Reply With Quote Quick reply to this message
Old 01-09-2011, 07:14 PM   #5
cruzcode
cruzcode's Avatar
Member # 6401
That is bad ass! Well done, thanks!
Can you please list the "K's" (relays and what they're for, as well)?
RC
__________________
A lot of chit coming...
W9DRC
cruzcode is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 08:19 AM   #6
z0666_07X
Member # 9753
is this any different in an '07, kinda looks the same, ive been starring at mine for 2 days trying to figure out why my rear blinkers don't work, is there any other fuse that relates to them besides M17/18
z0666_07X is offline   Reply With Quote Quick reply to this message
Old 04-14-2011, 09:48 PM   #7
Randyd
Randyd's Avatar
Member # 13621
If the front blinkers work, then look for a plug in the back loose or pulled out. or two burned bulbs?
__________________
Randyd is offline   Reply With Quote Quick reply to this message
Old 05-02-2011, 11:45 PM   #8
ronjenx
ronjenx's Avatar
Member # 10975
RC
Here you go:
Relays are labeled. The yellow circles are where power is always available.
Look here to see what's inside the TIPM:
http://www.jkowners.com/forum/showthread.php?t=50558
ronjenx is online now   Reply With Quote Quick reply to this message
Old 05-07-2011, 01:27 PM   #9
gstjim
Member # 15230
wiring a LED light
When I got this blinking light, it has 2 wires...one black (radio/wipers) and 1 red constant power. Heres the instructions:
*Red - connects to any fuse that has constant power.
(such as the Lighter or Dome Light Fuse)
*Black - connects to any fuse that is ONLY powered when the key is ON.
(such as the accessories or Radio Fuse) FUSE 24 WIPERS
This is most easily done by removing the selected fuse and
re-installing it with the LED wire partially in the socket hole
6. Turn on the key - the light should be off
Turn off the key - the light should Flash Red/Blue
My problem is locating the fuse that has constant power...
Can someone help?
Thanks!
Jim
gstjim is offline   Reply With Quote Quick reply to this message
Old 05-17-2011, 10:11 AM   #10
Owl
Owl's Avatar
Member # 14990
Thank you!!!!
Now, I don't have to put on my glasses, and get a magnifying glass!!!
Owl is offline   Reply With Quote Quick reply to this message
Old 06-05-2011, 12:43 AM   #11
jeepmedic08
Member # 15511
does anyone know the wire colors underneath the fuse box, more spificily the wire that goes to radiator fan from the j19 fuse. this is for a fan kill switch for water and mud!
__________________
2008 yellow rubicon unlimited
Rock krawler 2.5 stock mod w bilstines 5100's, and bikini top. black steelies 15's w 35's kumho road venture, trimmed bumpers and half the flenders
89 cherokee
helpless shell
97 wrangler
old DD
sold for gas money!
jeepmedic08 is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 07:50 PM   #12
pattjohnson479
Member # 3720
question
Here is a Bill of materials I found online for the 2008 Jeep. page 121 has the part callouts for all the fuses and relays.
http://d.scribd.com/docs/2k4ee67ul95m7ob8twn7.pdf
Its also usefull for finding other parts. Perhaps someoen can answer my question: according to that document. There is already a relay installed for factory fog lights. I have an X (no fog lights) can I just wire into that relay and run my Hella 500s?
pattjohnson479 is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 09:51 AM   #13
ronjenx
ronjenx's Avatar
Member # 10975
The illustration in the link is not the TIPM we have in our JKs.
Here is a picture of the "K" items in our TIPM. Notice there is no relay for the fog lights.
The fog lights are electronically controlled on one of the TIPM circuit boards, shown in the second picture.
Old 10-10-2011, 06:52 PM   #14
pattjohnson479
Member # 3720
thanks
ok thanks. I wonder what old document I got a hold of.
Old 02-11-2012, 12:23 PM   #15
cowboygraphics
Member # 19885
Came here to search and validate. Radio stopped working ... which fuse to change
Printed owners manual and RobertK list above indicate:
M10
20 Amp Yellow
Yet the photo above AND in my fuse box shows/has 15 amp BLUE. Pulled the 15 amp blue and does NOT look burnt/snapped.
Do I replace with 20 amp Yellow? Or is there another fuse more specific for the radio cluster? Manual is not indicating another fuse for radio.
cowboygraphics is offline   Reply With Quote Quick reply to this message
Old 02-11-2012, 01:33 PM   #16
cowboygraphics
Member # 19885
UPDATE: For M10 - do not replace 15 am blue with 20 amp yellow as spec in manual and text above. The manual is PROBABLY incorrect/typo.
In my case M10 fuse was NOT blown, but radio still did not work. Service manager suggested resetting by pulling out J13 and let sit for 1 minute to reset system then reseat the J13 back in.
J13
60 Amp Yellow
Worked for me - radio works.
Your mileage may vary.
Old 03-16-2012, 07:05 PM   #17
joeyjk
joeyjk's Avatar
Member # 11288
I have an airbag light on. Dealer said it was the TIPM, what fuse/relay is correlated with that?!?
07 door X
__________________
Roads...where we are going, we dont need roads.
joeyjk is offline   Reply With Quote Quick reply to this message
Old 04-30-2012, 07:13 PM   #18
Badd Andy
Member # 4349
thanks for posting this, you just saved me a huge headache tracing down an electrical problem
__________________
Blacked out 07 JKUR, safari straps, Treadwright 35's on stock rims and Spydertrax spacers, stubbied front bumper, trimmed flares, 2" body lift, 2" spacers in front with 1" spacers in rear, Gen Right Tire carrier, more to come!
Badd Andy is offline   Reply With Quote Quick reply to this message
Old 10-14-2012, 12:42 PM   #19
Dennisr
Member # 9809
Want led in the rear
Maybe you guys can help me out. I have a European JK with EU tailights and they have seperate indicator/brake lights. I want to change these taillights with led's, but the led's are US versions and share the brake/indicator light.
I asked a few wiring diagrams from the dealer and found out that the changes are withing the TIPM/front module. The only thing I don't know is; if it's a seperate relay/module, or if its a software change in the computer itself that states if it's a EU or US vehicle and uses the extra indicator wire.
Can someone enlighten me on this? If it's a software thing I can maybe ask the dealer to change my JK to a US version.
Thanks,
Dennis
Dennisr is offline   Reply With Quote Quick reply to this message
Old 11-01-2012, 02:30 PM   #20
Dennisr
Member # 9809
Bump, anybody
Old 11-19-2012, 07:51 AM   #21
Pemento
Member # 25400
JK tail led lights
Thanks,
Dennis
Hi Dennis. I have the same desire/problem. founds you the solution?
thanks a lot
Pemento is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 10:59 AM   #22
Dennisr
Member # 9809
thanks a lot
Not yet. And at this moment I don't have the time to investigate it deeper.
I think it's a setting in the wranglers computer, but I didn't call the dealer about it, yet. Maybe if you're dealership is willing to give you more information on these settings you can share it on this forum.
However there is another solution, but it's not really the one I want. I'd rather have my tipm changed, if possible
Old 11-21-2012, 02:56 AM   #23
Pemento
Member # 25400
rear lights conversion
I found it
http://www.etrailer.com/Custom-Fit-V...rt/C56190.html
Old 11-21-2012, 05:14 AM   #24
Dennisr
Member # 9809
If this is the way you're going let me know how it turns out. Offcourse you also need the resistors.
Ps. where do you live? Europe I assume
Old 11-21-2012, 12:15 PM   #25
Pemento
Member # 25400
tail lights
In Doha, Qatar. When the sistem arrives here i send to you a report
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
