Has anyone found a shorter antenna that will fit the JK? I keep catching mine on trees and bushes. I have a small aftermarket flexible rubber one for my XJ but none of the ones I've found so far fit the JK. It seems to have a larger threaded receptacle.
G, maybe with the antenna off you could swing by Sandy's on Mill Street and see if anyone knows what the connection size is called. Then we could scour the net for one.
Next step would be someone to take their antenna in to a Ham Radio store.
I thought I heard somewhere it was the same as the Libby one? Not that, that really helps yet.
I've been pounding the "Net' looking for an answer, because I'm real interested in doing this, some cut it shorter(not good), some runs without one(not good), some uses JB Weld to to fill the oversize hole(don't want to do that)......I'll be on this tonight, maybe an adapter >"Small to Biggiel" to fit the (Stubby Black Rubber Antenna) in our size hole. If I come up with anything I post tonight. With Pictures.
what about cutting it? i will prob just take mine off, i dont listen to regular radio anyway. wonder how hard it is to remove the whole mount and get another trail badge to go in its spot?
You could cut it, but then it would truly suck as an AM/FM antenna. But if you don't use it, guess it wouldn't matter. My hands won't fit up in there, it's too tight for me. I'd have to remove the fender which wouldn't really be all that hard. I'd imagine the "Trail Rated Badge" would fit fine.
I'd like the idea of a little black whip like antenna though.
The antenna mast is easily removeable from the outside. It has a set of male threads that appear to be 5/16 X 20. The rubber masts that I've found so far have a set of adapters with different thread sizes, but none are 5/16 X 20. I suppose I could have a custom adapter made but was hoping to not have to go that far.
I don't think I'd cut the antenna. I don't really use the AM/FM radio all that much (I have the Sirius option), so I could just remove it for now.
Hey gcg,,,,I just put a 5/16 NC 18 Die and screwed right on....I thinks it's 18 not 20. Now to go look at some Stubby Antenna's & see what size they are. I know they sell different size "unions" at true value, I've used them to go to a different size.
Here is a website that lists some of the US ham radio stores. Still think that may be a best bet to get the right radio geek, I'm not quite that geeky, to tell you what size or style the connector is. I doubt seriously that DC came up with their own without just outsourcing it from somewhere.
Gordon, if your pretty sure they are 5/16x20 (and not metric) than maybe just some calls about or emails should track this down fairly fast. I can't imagine a custom adapter to be required and again I doubt DC did this on their own.
Here ya go, bought a $5 antenna A&A Auto, Bought a 1/4 threaded union(True Value) & a 5/16 X 18 bolt $4, drilled out one end down in (1/2" in), used 5/16 Tap(cut thjreads, g screwed it in & cut bolt to proper length(hack saw), used 1/4 stud provided with Antenna the other end, went out and Whammy......Radio works just great. You'll see the 1/4 stud in the picture & 5/16 at the other end:
Here is the little gissmo screwed into Antenna.....
Great work! It's always nice to see a simple solution that works. Sorry about the wrong thread count (I originally thought it was 20) - I went to Home Depot today and found that it was 18, too, but hadn't gotten around to posting it.
I really like your solution. I think I'll give it a try myself! Love the way this forum works!
Great idea, especially if it works........Question,, did you have front & rear OX Lockers installed or other Lockers with OX Covers.
Best License Plate you could ever put on the front....
Semper Fi. & Great Looking Rig.
Related Threads
JKOwners Forum
2M posts
62.8K members
Since 2007
A forum community dedicated to Jeep Wrangler JK owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, reviews, engine swaps, troubleshooting, suspension, and more!
