Which Gears 4.88 or 5.13 - JKowners.com : Jeep Wrangler JK Forum
Old 12-01-2009, 12:26 PM   #1
btircuit
btircuit's Avatar
Member # 5970
Took the first highway drive this weekend since the 35's were installed. It drove fine as long I kept it around 60-65 but as soon as I pushed it to 70 it started a down shifting cycle every 20 seconds or so. No way I can live with it this way... gotta get new gears.
Now the question is 4.88 or 5.13's? I really don't see myself going any larger than 35's so I'm leaning toward 4.88.
What do you guys think?
btircuit is offline   Reply With Quote Quick reply to this message
Old 12-01-2009, 01:29 PM   #2
GreenAmphibious
GreenAmphibious's Avatar
Member # 4016
have you used a procal or something to adjust the speedo (tire size)? I did it after installing 35s and it helped the gear search
__________________
2015 JKU Sport Virgin
GreenAmphibious is offline   Reply With Quote Quick reply to this message
Old 12-01-2009, 01:41 PM   #3
btircuit
btircuit's Avatar
Member # 5970
Yeah, did Pro Cal speedo and tire size so I figured it's down to re-gearing.
I'm with ya... 5.13's. Do them once and forget it.
Thanks
Old 12-01-2009, 04:43 PM   #4
SoK66
SoK66's Avatar
Member # 4483
Let me be the contrarian here, I had to make the same decision. Being of the opinion I'd never go beyond 35s on a JK with stock axles, I opted for 4.88s. The reason being that at cruising speed the 4.88s will have the RPMs at just over 2k, just about perfect. Using the AEV module to recal for 35" KM2s I've had no issues whatsoever with OD hunting, etc., and in low range it crawls great. JMHO, of course.
SoK66 is offline   Reply With Quote Quick reply to this message
Old 12-01-2009, 05:06 PM   #5
GreenAmphibious
Member # 4016
things to consider:
Rubi? you have 4.10 and going to 4.88 would be worthless and a waste of money
Daily driver? trail rig? daily driver/andtrail rig?
auto? stick?
35s now but ever going bigger?
no matter what you answer I would go with at least 5.13
__________________
Old 12-01-2009, 06:18 PM   #6
isoyeti
isoyeti's Avatar
Member # 2024
I just did 5.13's w/37's. 6-sp. 1st gear is actually useful now. 6th gear at 60 mph (I did use the procal to adjust the speedo) is about 2400 rpm's, seems a bit high to me. I wonder what 5.13's and 35's would be?? Fuel economy has gotta suck... but since I don't keep track of mine and really don't care anyway, I don't really know.
isoyeti is offline   Reply With Quote Quick reply to this message
Old 12-01-2009, 06:19 PM   #7
GreenAmphibious
Member # 4016
2400 is fine..... these litle hamster wheels like high rpms
__________________
Old 12-01-2009, 09:55 PM   #8
btircuit
btircuit's Avatar
Member # 5970
It's a Rubicon Auto 4.10's pulled behind an RV used mostly for trail riding.
A friend has the same setup with 4.88's and has been somewhat happy but says he'd like to go to 5.13's. But he's also considering 37's which I"m not.
Coin flip...
Old 12-02-2009, 07:17 AM   #9
thebigtman
thebigtman's Avatar
Member # 2606
There is a TON of info on here regarding this very issue. It took me a few minutes but I dug up a good post.
Although most of this info pertains to the manual, this is a good read as it gives you some perspective on the JK auto tranny numbers after a regear.
http://www.jkowners.com/forum/showth...s+rubi+highway
Xtremjeepn made an excellent point in that thread that you should consider:
The Auto has an INSANELY deep overdrive compared to the stick. Run this number. A Rubi, 4:10 6 speed with 35s rolling down the highway is 40 rpm(yes, 40) less than an Auto with 5:13s and 35s.
So, you'd need to go to at least 5:13's to bring it back to stock. Many have even gone to 5:38's. Once you get too deep you need to consider pinion size and contact patch. I don't know the reliability of the 5:38's on the stock d44's but from what I've read on here people are having good luck so far. If you're mostly trail riding the deeper gears are obviously a better choice for you. Furthermore, since you'll add the heavier tires/wheels you're now making that engine work even harder. This doesn't even factor in the armor and other stuff you pack in the JK when heading down the trail. If you weigh your JK once it's loaded down, you'll find that it's around 5.5K to 6K lbs.
Make sure you read this thread too. It's got some good numbers on it. http://www.jkowners.com/forum/showth...ght=5%3A38%27s
GOOD LUCK and I hope this helps.
Tim
thebigtman is offline   Reply With Quote Quick reply to this message
Old 12-02-2009, 07:50 AM   #10
GreenAmphibious
Member # 4016
auto w/35s = 5.13 NO DOUBT
__________________
Old 12-02-2009, 09:31 AM   #11
btircuit
btircuit's Avatar
Member # 5970
Very Helpful
Thanks for the links... great food for thought.
Old 12-02-2009, 09:36 AM   #12
Jason @ Warrior
Jason @ Warrior's Avatar
Member # 1393
5.13's
I'm on my 4th or 5th JK in the shop and any combination of tranny and tires that were 35+ I always wished I would've gone lower than that 4.88's in the ones I regeared to 4.88
__________________
I no longer work with Warrior. I am now working with The FIRM.
Jason @ Warrior is offline   Reply With Quote Quick reply to this message
Old 12-02-2009, 12:01 PM   #13
steves07jk
steves07jk's Avatar
Member # 4364
Thats funny I was just thinking the same thing I am getting 35s and will be regearing in feb or march but didnt know what I wanted to go to. So I am going to watch the thread
steves07jk is offline   Reply With Quote Quick reply to this message
Old 12-02-2009, 03:14 PM   #14
Mall Krawler
Mall Krawler's Avatar
Member # 1734
If you have the Dana 30 in the front I would stay with 4.88. If you play hard you will chew up the 5.13 ring gear. I went through a few.I was fine just playing on the trail rides but when I started to run it in the comps. You play a little harder and then you get that oh so familiar sound of teeth stripping.
__________________
Mall Krawler is offline   Reply With Quote Quick reply to this message
Old 12-03-2009, 06:35 PM   #15
planman
planman's Avatar
Member # 3083
I have never seen a post about properly installed gears on a JK failing with 37" or smaller tires unless it was part of a catastrophic failure that would have damaged any size gears.
So, the evidence would suggest that the gearset is not the weak link in JK axles and you shouldn't worry about putting 5.13s in a JK Dana 30, or 5.38s in a JK Dana 44. If you have seen a compelling number of JK gearset failures due to small gear teeth, please point them at least one out to me on any forum.
As a result, with an automatic, I'd go absolutely as low as you can go. For a Rubi, that is 5.38s, for a non-Rubi, that is 5.13s.
The JK engines require higher rpm levels than the old 4.0L TJ engines. They really need to be run over 2500 rpm at highway speeds to produce enough rear wheel horsepower to drive in windy situations, towing, up grades, or at higher elevations to avoid flashing the converter (downshifting with tranny slip that revs the rpm levels higher than they would otherwise be in just 3rd gear with the overdrive off). I am not an engineer or a rocket scientist, but I can tell you that 64 rear wheel horsepower at 2k rpm is not adequate to roll 35" tires on a non-aerodynamic brick of a lifted JK in windy, towing, graded/hilly, or higher elevation (i.e. Rocky Mountain West) situation. Maybe on low elevation, flat highways, on 2 doors, with little or no lift 64 rear wheel horspower at 2k rpm is sufficient, but not for the rest of us.
Gas mileage will improve for automatics that run at 2500 rpm at highway speeds due to the reduced flashing of the converter (downshifting, etc.).
This is not opinion or casual observation. Clearly, the automatic JKs are undergeared stock and the Rubi's should have come with 4.56s or 4.88s stock.
Here is the evidence of the JK rear wheel horspower at different rpm levels:
Here are the rpm levels by tranny type, gear, and tire size (notice that the rpm levels of 5.38s are barely more than 5.13s, making 5.38s preferable with an automatic Rubi with 35" or taller tires):
__________________
planman is offline   Reply With Quote Quick reply to this message
Old 12-03-2009, 06:55 PM   #16
thebigtman
thebigtman's Avatar
Member # 2606
Good post.
Old 12-03-2009, 07:32 PM   #17
steves07jk
steves07jk's Avatar
Member # 4364
Ok so which brand would be the best to go with? Alloy usa , motive gear or the g2?
Old 12-15-2009, 07:50 PM   #18
steves07jk
steves07jk's Avatar
Member # 4364
Anyone got a good choice or best brand of gears to go with?
Old 12-15-2009, 10:44 PM   #19
planman
planman's Avatar
Member # 3083
I would just call one of the supporting vendors here and ask their opinion--probably Phil (owns Trail Duty).
__________________
Old 12-15-2009, 10:50 PM   #20
STANGJEEPER
STANGJEEPER's Avatar
Member # 3236
I went with the Yukon gears, Im sure others are ok as well. most are made by the same manufacter and relabled before sale. but to be safe. Go with Yukon.
__________________
08 Rescue Green Rubi - SOLD
O5 - LJ Rubicon RK Xfactor long arm
STANGJEEPER is offline   Reply With Quote Quick reply to this message
Old 01-10-2010, 09:41 AM   #21
mgbug
Member # 7603
Would GR apply to me?
I have a 6spd 06 Rubi with 4.0. I use the thing a lot on highway @ 70-75 mph. I hate seeing the engine rev so high. In 6th I tach 2700 @ 70mph. Can I use this chart to select a larger tire to stay in the green range yet give the engine a break? My 4.0 91 Wrangler (5spd) was in the 2200 range at these speeds if I remember correctly and that engine was running like a top when I sold the Jeep @ 197,000 miles. Great post by the way.
Bob D
mgbug is offline   Reply With Quote Quick reply to this message
Old 01-10-2010, 10:43 AM   #22
steves07jk
steves07jk's Avatar
Member # 4364
So alot of people say since this is my daily driver 4.88s would be the way to go but then othrs say all the weight you add you should do 5.13s damn such a hard choice
Old 01-10-2010, 11:15 AM   #23
d'sjk
d'sjk's Avatar
Member # 5640
I am trying to make the same choice and honestly after talking with some people and riding in a guys with the 5.13 gears I am now set at 5.13's and actually if I had the front dana 44 I would be doing 5.38's
My Jeep is a daily driver but I think that the 4.88's will fall short of some of my expectations and the difference between the 4.10's and the 4.88's does not really backup the price as the 5.13's do.
__________________
d'sjk is offline   Reply With Quote Quick reply to this message
Old 01-10-2010, 12:35 PM   #24
tank
tank's Avatar
Member # 971
Location: Stuck in Norfolk Nebraska home of no Wheeling
they should put 4.88s in stock. go with the 5.13s.
i have 5.38s in and love them.
__________________
[x] 4in la lift [x] 37in Pro comp E/MT tires [x] eagle 17in 101 wheels [x] super chips [x] ORE outlaw rear fenders [x] ORE C gussets [x] ORE magnum 44 sleeves[x] 5.38 gears
[x] RR front bumper [x] xrc 8000lb winch [x] home brew cage [x] RR front bumper [x] home brew rear bumper [x] home brew front grill guard [x] home brew tube fenders
[x] home brew rubi sliders[ ] red neck ram[ ] 2in bb[ ] 40s
tank is offline   Reply With Quote Quick reply to this message
Old 01-10-2010, 12:41 PM   #25
bubba2u
bubba2u's Avatar
Member # 5552
i have the been wondering about the gear manufacturers. i hear about noisy gears with some brands. i understand yukon is made in china. is there a quality American made set of gears available? i would like to run a 4.56 with my 6 speed as i don't think i will go over a 35 inch tire, let alone allot of advertised 35 inch tires are more like 34"
bubba2u is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
