| Register | Active Topics | Garage | iTrader | Calendar | Mark Forums Read | Premium Memberships | Auto Escrow | Auto Loans | Insurance | Advertise |
Share | Thread Tools | Display Modes |
#1 |
Member # 100
![]() JK D30 Ausie Locker Install Just finished installing an Aussie locker in my D30. I have not seen any JK specific installs out there so I thought I would do a quick write up to hopefully save others a couple of headaches I ran into. Thank you A Plumber for letting me use your garage and K-bear for all your help! I owe you guys one! Sorry I didn't get more pics, I kept forgetting throughout the install. I used a write up from 4x4xplor.com (for a TJ) as well as the Aussie supplied instructions: http://www.4x4xplor.com/aussielocker.html http://www.offroadlockers.com/display/Manual_d.pdf Aussie Locker (XD-13027): http://www.aussielocker.com/item.php...0/310025/.html Riddler Diff Cover: http://www.trailduty.com/product_inf...roducts_id=619 Dana 30 Lube LOcker (LLR-D030): http://www.lubelocker.com/products/catalog.html Tools needed:
Install:
| Sponsored Links | |||
Advertisement | |||
#2 |
Member # 100
#3 |
Member # 100
#4 | |
Member # 100
#5 |
Member # 100
That should be it! Back up right over your chocks since you now have a badass 4x4 rig!
I will provide some feedback here as soon as I get a chance to check it out! ![]() ![]() ![]()
#6 |
TOOL GUY
Member # 291
Nice job, where did you go today? I know you just got that cover on last night, and it looks like you wheeled already
__________________
Tools, Tools and more TOOLS! JOIN OUR FACEBOOK PAGE "The best beer cooler in the world will always be the edge of your favorite river." |
#7 | |
Member # 100
http://www.jkowners.com/forum/showthread.php?t=1843 I didn't have a chance to give it a real work out but from what I did it worked great! There was deffinetly a couple of off camber snow drifts that where way easier then they would have been without it! Hopefully I will have a chance to give it a good work out soon so I can report back on how it did. |
#8 | |
Member # 75
![]() #1- Receive Aussie Locker #2- Drive to 4X4 Shop & Drop Off #3- Go back at 4 PM pay a Rediculous Install Fee & Drive Home.I think the Aussie made my JK a Completely different Wheeler.
__________________
Jim, USMC 0311 - 1811 RVN (Dec 67 - Aug 69) DAV, DMZ "Leatherneck square"((To All The "November Charlie Foxtrot's" that think they know)) You Are Clueless G27 , G26, & G22-C |
#9 |
Member # 1151
how do you like em??
What's up Chris?? Hey how do you like the Aussies?? Glad you experimented on yours, now when I get to Denver you can help me put mine in!!
Did you notice a huge difference?? Any additional noise while driving on roads?
__________________
Lifted by Poly Performance, JKS DC's, Skid Row Protected, ProComp 7105, Kevlar MTR's, HD CUSTOMS Switchblade rear, Red Rock Fab stinger etc... |
#10 | |
Member # 100
![]() I like it so far. I have not had a chance to work it out too much yet but so far it has completley changed everything, lol. It is a monster now. No need for the skinny pedal, just crawl right up!! There is a little faint ratcheting when turning sharp like in a parking lot but nothing that is too bothersom. Offroad I have noticed a little clunking once in a while but I think some of that was just them being new, by the end of the day there was much less noise. I will be more then happy to help you with an install! Should be pretty easy and go fast now that we figured out some thingsd during the install I did! |
#11 | |
Member # 100
How long have you been running yours? Do you get much noise when in 4wd off road? |
#12 | |
Member # 75
. You can just feel it working on hard rock situations, got high centered & spotter come over & said your Aussie is definitely working.On road 2WD nothing at all until a lock to lock slow turn(parking), a little chatter. I wish they had one for the D44,,,,,,,,,,,,,,,I'll lock both ends.
__________________
#13 |
Member # 1151
ooops.. Sorry dude.. That is what I get for trying to use my memory. I got everyone mixed up! I shoulda just checked your sig! Well have a for the install and I can't wait to get these in my dana 30!
__________________
#14 | |
Member # 100
I just want to ad a little info.
The most confusing part of this install was the proper way to measure the tolerances. This is the part that made our install take so long. I had read on JK-forum that a couple guys where saying the JK thrust washers where too thick and they used a TJ washer instead which are slightly thinner. The thing about it though is the guy said he used one TJ and one JK washer which makes no sense as the Pinion shaft is fixed, this would work if it floated but by my calculations it would mean he was tight on one side and loose on the other. If you used two TJ washers you would be too loose. You see, the thrust washers in the JK have a quite a bit of spring to them. At first we thought we where too tight. Then we realized that if we pried them open we where within tolerance. It was not really clear from the instructions if you should meet the tolerances while it was at rest or while pried open. So far everything has been working fine but I thought I would check with Aussie to be sure: Quote:
#15 | ||
Member # 100
bit more info...
#16 |
TrailDuty.com
Member # 143
Very nice write up
![]() Everyone I know with Aussie lockers loves them. |
#17 |
Member # 260
Well I installed a full set of Teraflex control arms on Saturday and today I put a XD13227 JK specific Aussie Locker in my 2007 unlimited. This was a great write up, I've read through it a few times over the time it took for this locker to come out. When it came to installing it the pinion shaft wouldn't go in. I cleaned the excess grease off but no go. I called Aussie and while waiting for a tech to call back decided to try the stock thrust washers. They are about half the thickness of the new blue ones that come with the JK specific locker. Long story short they work, shaft to axle gear spacing .012 inter cam gear spacing .160. The tollerance is .006-.020 and.145-.170. When the tech called he said they Jeep had changed a few things in late 07 / 08 on the front ends and mine would work fine like that as most kits reuse the stock thrust washers. Mine was built on 11/06 so it could be an older D30. Anyway thanks again for a very usefull and well written write up.
Ron O. The thrust washers on my front end are flat, no spring as yours had. |
#18 |
Member # 100
interesting. Thank you for the response.
So, laid flat they are perfectly flat? no cup to them at all? How thick are your thrust washers? |
#19 |
Member # 1770
If you want to know an easier way to remove the carrier, just put a wrench on one of the carrier bolts and rotate the pinion. I cant remember what way to go, but it will rotate until the wrench hits the housing then it will gently rotate the carrier out of the housing. Easiest way to do it without a spreader
#20 |
Member # 260
Thrust washers.
They are as flat as the table on my drill press, and thats pretty flat. The blue ones that come with the JK specific Aussie locker are .047 acording to the Aussie tech. The battery in my micrometer was dead so I can't confirm this today. The 2 stock thrust washers stacked are close to one of the new blue ones, I think a little more Its been a long day so I can't remember. All I know is I waited a year, paid $30 or $40 dollars more and didn't need those washers. The worst part is I could have been locked in Moab last summer and wasn't. Oh well I'm heading down there again in October this year and I'll be more prepared. Whats the weather like down there in October temp wise and how early does it get dark? It was great last July but friggen hot.
Once again thanks for the write up. Ron O. And yes no spring or cup to them, could be the left over parts they had in November 06 builds. Anyway I've had no problems before and the install went good. Now It's back to work for 9 days before I can test it properly. |
#21 | |
Member # 4676
I'm SO glad mine wasn't one of these when Bill was looking for a test subject JK. Bill from Aussie Locker and a fellow club member and Jeep tinkerer, Ryan, adding the small springs to the locker before final assembly. ![]() I'd say I was pretty lucky. be a guinea pig and get a locker out of it. ![]() Oh, and the locker works GREAT! Was crawling up sandy hills that would have choked it before. |
#22 |
Member # 5256
That looks great. Just wondering if you have regeared yet? This looks like it may by my new best option over swapping to a D44 Front end. Also when do you want to give me a hand installing one on mine?
__________________
Seize The Carp 35x12.50 BFG KM2 4" Frankenlift Aberle Offroad JKS Rancho Superlift Rough Country Teraflex Poly Performance Mickey Thompson Poison Spyder Ohana Fab Rock Hard Smittybilt PIAA Daystar Flowmaster Hypertech Body Armor Airaid AEV Aberle Off Road Aluminum Products for your JK and Dodge Ram
aberleoffroad.com |
#23 |
Member # 3316
PICS? !!!
__________________
We the People of the United States, in Order to form a perfect Union, establish Justice, insure domestic Tranquility, provide for the common defense, promote general Welfare, and secure the Blessings of Liberty to ourselves and our Prosperity, do ordain and establish this Constitution for the United States of America. |
#24 |
Member # 11876
any chance you can re host these pictures!! please!
#25 |
Member # 260
If you use Aussies manual and the tips from WTFs writup its an easy install.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
