rear seat removal - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > Regional Forums > USA - Florida
Old 11-19-2009, 07:48 PM   #1
Bubba322
Bubba322's Avatar
Member # 6621
rear seat removal
Can anyone advise on how to remove the rear seat on my 2009????
Bubba322 is offline   Reply With Quote Quick reply to this message
Old 11-19-2009, 07:51 PM   #2
Jpaye
Member # 5897
it just bolts in right?
Jpaye is offline   Reply With Quote Quick reply to this message
Old 11-19-2009, 07:54 PM   #3
oz97tj
oz97tj's Avatar
Member # 3528
Big hammer....
On the back of the seat between the headrests is a plastic lever. Lift it up and the back will fold down. Once it folds down, you will be able to tilt the whole seat up. Once it's folded up, you can lift it off the two pegs at the front.
oz97tj is offline   Reply With Quote Quick reply to this message
Old 11-19-2009, 07:55 PM   #4
oz97tj
oz97tj's Avatar
Member # 3528
Big hammer....
Kind of obvious, but you should be standing outside at the back of the vehicle to do this.
Old 11-19-2009, 08:29 PM   #5
mikeyfl
i want an umbrella.
mikeyfl's Avatar
Member # 103
not my instructions, but should help.
I have the subwoofer, which the Jeep manual says to remove and disconnect prior to removing the backseat... don't bother (if you're strong enough to handle the seat by yourself, this is a total waste of time).
OK - in step-by-step form:
1) Open the tailgate and rear hatch (if you have the soft top on, tie the rear windshield panel out of your way). Climb into the "cargo" area.
2) Use the "fold-and-tumble" feature (you may need to adjust your front seats to provide enough clearance for the backseat to pivot forward properly - this is important).
3) Squeeze the pressure bar at each side, where the folded seat attaches to the cargo floor - you don't have to squeeze particularly hard, but you WILL need to squeeze to disengage the floor clasps from their mounts.
4) Lift FIRMLY upwards and backwards while squeezing the pressure bar - the goal here is to disengage the clasps from the floor mounts. Not very heavy, just awkward to do (go ahead and get mad at it, then give it a good tug - worked for me).
5) CAREFULLY pull the folded, disconnected backseat backwards toward the rear opening - if you have the subwoofer and left it installed, exercise care not to smash it, etc.
6) Gently stand the backseat on its end behind your Jeep - climb out.
7) Store the rear seat wherever, and enjoy the newfound rear visibility, cargo space, and extra 1/3 mpg!
__________________
the above is most likely irrelevant.
jk-forum, jk forum, jkforum, jeep jk wrangler, abendx is my hero, project-jk, jeep JK, JK wrangler, JK, JKO
mikeyfl is offline   Reply With Quote Quick reply to this message
Old 11-19-2009, 09:25 PM   #6
Bubba322
Bubba322's Avatar
Member # 6621
thanks for the help!!! i just went outside and removed the rear seat.
Old 11-20-2009, 06:51 AM   #7
rjmcam
rjmcam's Avatar
Member # 1025
OR Attach snatch strap to tree, wrap around rear seat- with tailgate open, place Jeep in drive and push down on the long skinny pedal...LOL
__________________
Jeep is gone
rjmcam is offline   Reply With Quote Quick reply to this message
Old 12-21-2009, 10:19 AM   #8
rdhrd4
rdhrd4's Avatar
Member # 6573
win!!!
__________________
I LIVE, I RIDE, I DESTROY, ANYTHING I GET BEHIND THE WHEEL OF
But you either support your troops or you are shit.
rdhrd4 is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
