JkOwners.com - The Community for Jeep JK 4x4 Owners
Go Back   JkOwners.com - The Community for Jeep JK 4x4 Owners > JK Tech > Write Up Dept. (The Library)
Old 04-30-2008, 07:47 AM   #1
TiredIronGRB
TiredIronGRB's Avatar
Member # 733
Bulldog Bumper and Winch Install
Here's my install write up on the JK bumper and 10K winch.
My BullDog winch and bumper arrived well packaged and undamaged.
The workmanship and finish on the bumper was flawless.
All the mounting hardware was nicely packed and all there, all I needed was a Phillips screwdriver, and 10, 12, 16, 18 and 22mm wrenches and sockets.
The driving light holes had blanks for JKs not equipped with them.
The bumper mounting bolts were welded to a plate and held in place with a 3/8" pin to make installation easier.
First remove the air damn under the bumper amd the filler between the bumper and grill, I found that a valve core removal tool (pointed end) works great to get the plastic expander screws out.
Next remove the four bumper mount nuts and plates from each side. Before removing the last two nuts unplug the driving lights (if equipped) and lossen the wiring from the bumper.
Then remove the driving lights from the old bumper.
Use the screws that held the blanks to install the driving lights.
__________________
"Too Blessed to be Stressed"
www.4x4Grace.com
TiredIronGRB is offline   Reply With Quote
Old 04-30-2008, 07:48 AM   #2
TiredIronGRB
Member # 733
With the driving lights in place place the new bumper in place and start a nut on each side to hold it in place.
Use the flat and lock washers under each 22mm nut to secure the bumper to the frame.
Now to install the winch into the bumper, be sure to install the ground wire to the bottom of the winch motor before placing winch in bumper. The winch is the 10K model, I really like the solenoid housing and stainless steel hardware.
Four 16mm bolts secure the winch to the bumper from underneath.
The fairlead is held on by two 18mm bolts.
Pull the cable through the fairlead and secure the hook and line flag.
Run the power cables directly to the battery 10mm negative post 12mm positive post.
The winch controller connects at the top of the winch and has a lock witch holds it firmly in place.
After testing the winch it was time to install the skidplate.
The front bolts to the bumper with five button head allen bolts.
__________________
www.4x4Grace.com
Old 04-30-2008, 07:48 AM   #3
TiredIronGRB
Member # 733
The rear bolts to the air damn mount with four 16mm bolts.
Besure to use the large flat washers supplied in the hardware kit as the holes in the air damn mount are larger than the stand flat washers.
The bumper came with a nice light bar which I opted not to use since I'm not going to run any extra lights.
The fit and finish of the winch and bumper are excellent and was very easy to install, it can be done in less than two hours by one person.
BullDog also has a very nice logo!
__________________
www.4x4Grace.com
Old 04-30-2008, 08:57 AM   #4
venom
I run with scissors too!
venom's Avatar
Member # 146
Thats a good looking setup
I wonder if the skid plate would work with some other bumpers - like maybe my mopar
venom is offline   Reply With Quote
Old 05-09-2008, 04:16 PM   #5
md_rubi
md_rubi's Avatar
Member # 567
do you know if those will work with Warn PowerPlant? also can you please post pic of your jeep from the front? I'm looking to rplace my Shrockworks Mid for a stubby.
md_rubi is offline   Reply With Quote
Old 05-09-2008, 06:31 PM   #6
TiredIronGRB
Member # 733
Yes, I sure it would...there was plenty of room. I will try and get a picture from straight on tomorrow.
__________________
www.4x4Grace.com
Old 05-12-2008, 05:16 PM   #7
md_rubi
md_rubi's Avatar
Member # 567
that would be great. if the powerplant fits i might have my SW mid replacement. How do you like the bulldog bumper?
Old 05-12-2008, 06:10 PM   #8
TiredIronGRB
Member # 733
I love the bumper, it's very well built and super easy to install.
__________________
www.4x4Grace.com
Old 05-13-2008, 04:40 AM   #9
md_rubi
md_rubi's Avatar
Member # 567
I borrowed a set of 39.5" tires to see if it will clear with my new fenders and everything looks fine during articulation except for the front bumper when I turn my wheels. this is the only reason I'm thinking of replacing my SW mid bumper.
Old 06-14-2008, 06:52 PM   #10
TiredIronGRB
Member # 733
I added some 3M skid tape that covers the mounting holes where the light bar goes.
__________________
www.4x4Grace.com
Old 06-15-2008, 10:31 AM   #11
airric00
airric00's Avatar
Member # 1151
Nice set up!!!
__________________
Lifted by Poly Performance, JKS DC's, Skid Row Protected,
ProComp 7105, Kevlar MTR's, HD CUSTOMS Switchblade rear, Red Rock Fab stinger etc...
airric00 is offline   Reply With Quote
Old 09-06-2010, 11:05 AM   #12
Butkus34
Butkus34's Avatar
Member # 10823
Great idea with the tape, looks really nice!
Butkus34 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
©1996 - 2009 Pirate Media Group
