how to find an underground electric wire?? - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > Miscellaneous > Chit Chat
Old 10-18-2009, 07:57 AM   #1
savage
Member # 6162
I hate asking this kind of stuff on these boards but thought maybe you guys may know a trick that would help me find an underground wire. This wire runs out of the fuse box outside and up a hill to our shed. It has been cut several times and has no juice to it, but i need to get it running again before winter. Ive tried metal detectors with no luck, i know the general area where it is though. I dont want to dig it up from the shed down to the house its about 300 feet id say. Once i do have it, whats the best way to wire it back up?
I planned on buying it in PVC pipe and capping the ends and try and seal up my connects the best i can. I hope i make sense, thanks for any suggestions!
savage is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 08:11 AM   #2
Crazy X
Crazy X's Avatar
Member # 1692
I Know here in Sebring you can call before you dig and they will come out and mark any lines which are Underground with flags.I guess when the person goes out there you can ask him to help you find the wire to the shed.Its free here where I live.
__________________
There is only one tactical principle which is not subject to change. It is to use the means at hand to inflict the maximum amount of wound, death, and destruction on the enemy in the minimum amount of time."
- General George Patton Jr
Crazy X is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 08:53 AM   #3
Broncojohn
Broncojohn's Avatar
Member # 1571
No juice, it's going to be rough. The power company has some neat toys, if you can keep power on it. You can try the "push rod" but unless its in conduit your poking for a needle in a haystack.
To find mine I guessed were it should have been and started digging. It took 3 holes to find the break. F#$king gophers.
__________________
Broncojohn is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 09:20 AM   #4
Alec W
Guest
Member #
Posts: n/a
If you have no clue where itís broken you may be better off renting a ditch witch and running a new line. Iíve got some major sprinkler system problems and think it will be faster to run a new section than find breaks and repair.
http://homedepotrents.com/proTools/trencher.asp
Old 10-18-2009, 09:31 AM   #5
Slippery
Slippery's Avatar
Member # 4627
Hook some power to it. Use a metal detector to follow it til it ends, mark, cut power, dig, and repair. Repeat until all cuts are repaired.
__________________
Slippery is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 10:30 AM   #6
savage
Member # 6162
no way to hook power up to it. (unless i could hook it up from the shed back down toward the house somehow...) here is the short of the story...
Sisters house, she had a fence out back and wanted it out. A friend and I got to digging it up for her, WHAM he cut the wire with a shovel and got a little shock... Cut #1. We attempted to repair it but do not know if it was truly fixed, another long story (messed up breaker box.)
Now i bought the house a few years later, and we had to put 2 drainage ditches in with a ditch witch... Cuts #2 and #3 were made at that time. lol
So what im guessing is i just need to get to digging and see if i can find it. If i cant find it then i guess i could start pulling up from the shed down the hill and run it all over again.
Old 10-18-2009, 10:32 AM   #7
Slippery
Slippery's Avatar
Member # 4627
You are better off to grab a ditch witch and lay a new one. The splices will just cause you trouble down the road anyway. Good luck!
__________________
Old 10-18-2009, 10:41 AM   #8
MichaelW
Broker by the Minute
MichaelW's Avatar
Member # 20
x3 on this. I think it was suggested at least once in this thread before. If there is no slack in the line... repairs will be.... a challenge. Get the ditch witch, bury the wire in conduit, done deal.
MichaelW is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 10:42 AM   #9
savage
Member # 6162
the only ditch witch for rent is way too big to deal with. we've used it before. Its all hillside here too so it would be crazy tough.
Old 10-18-2009, 11:10 AM   #10
tkob1060
tkob1060's Avatar
Member # 5021
like others have said I would run a completely new line.....but if you want to repair it again I would check where you made the 3 previous repairs. I wouldnt doubt they havent held up underground for a few years.
__________________
tkob1060 is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 11:27 AM   #11
bsack
bsack's Avatar
Member # 396
I'd bury new wires in metal conduit with sealed connections to avoid any new problems, and make it possible to pull new wires at a later date if you need/want to.
bsack is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 12:51 PM   #12
paramaniac
paramaniac's Avatar
Member # 5392
i hate to sound like a repeater... but there really is no other safe way. even if you find all the breaks, make the repairs and put a GFCI in place, those things can fail. if the ditch witch is too big, go medieval on it and get yourself a sturdy pick axe and a mattock tool and dig your own trench. lay in some PVC conduit with your power line snaked thru it.
i know its not the "easiest" of solutions, but its probably (note i said probably) the best...
good lcuk
__________________
paramaniac is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 12:54 PM   #13
savage
Member # 6162
yeah i guess it just sucks, there is 300 ft of good wire that is fine, its the first 20 ft close to the house that got cut in 3 spots.
Old 10-18-2009, 01:02 PM   #14
Slippery
Slippery's Avatar
Member # 4627
My electrician buddy would hook power to the wire end you have. Just energizing the wire emits an electrical signal that can be traced with a metal detector, or wire finder. I don't understand the "I can't", cause if you are goin to use it, you must have an end in a breaker box, so splice a wire to it from a good breaker and give this a try.
Hook power to it and trace with a metal detector. If he tries that and it's shorted, so it pops the breaker, he lays where he thinks the end is, have someone energize the breaker, and you can here the pop under ground and find it.
If he had to, he could run power out to the other end, and energize it, and trace it up from that end.
It can be done. Sounds like it's worth a try.
He does this stuff, and is quite good. Don't ask me, I don't know.
__________________
Old 10-18-2009, 01:43 PM   #15
savage
Member # 6162
If i could draw it out it would help explain, but i cant.
right where the wires come out of the house is where it got cut the first time then 2-3 feet from there cut again, then 5ft or so cut again, then the rest of the wire goes up the hill to the shed. if i can find the last cut near the hill i can splice onto it then head it back into the house with the fuse box. i never attempted to fix cut 2 & 3 because i knew it had been cut long ago at 1. (really sorry if this is getting confusing)
the method your talking about would work prefect if the cuts were at the other end of the wire (close to the shed.)
here is the best i could draw it up:
Old 10-18-2009, 01:51 PM   #16
bsack
bsack's Avatar
Member # 396
I think we are all on the same page with you. Personally I think its a good idea to get the wires in conduit and that is what I would do in this situation. I wouldn't be content with wirenuting wires underground. Its more work now but could save you future headaches. But like has been mentioned earlier, utility companies will often locate wires for free. Just call and tell them you want to put a fence in the general area where you think the break may be an they will paint it out for you. Any bogus story will work that will get them to plot your utilities in that area.
Old 10-18-2009, 02:03 PM   #17
savage
Member # 6162
hhhmmm
unless they have some kind of tool to find it i dont think they would know where it was, the previous owner laid it down years ago. I may make a call and just see what they say. if there was some way i could juice it from the breaker in the shed that would work...
Old 10-18-2009, 02:07 PM   #18
Slippery
Slippery's Avatar
Member # 4627
hhhmmm
it's worth a try, before putting up light poles and running it above ground!
__________________
Old 10-18-2009, 02:08 PM   #19
savage
Member # 6162
now that would be some work! lol
Old 10-18-2009, 02:12 PM   #20
bsack
bsack's Avatar
Member # 396
hhhmmm
Tell them you want to run a fence from the corner of your house to shed about where you believe the wires run. They should plot the wires for you. Don't mention that you are looking for a break in the wires. Worth a try.
Old 10-18-2009, 02:19 PM   #21
Slippery
Slippery's Avatar
Member # 4627
I don't think they will show up without some sort of signal on them. Sometimes they have a radio frequency sending unit they can set by the wire where it comes out of the shed if you know where it is, or hook into the panel.
__________________
Old 10-18-2009, 02:20 PM   #22
Broncojohn
Broncojohn's Avatar
Member # 1571
If all the cuts are up by the house, get to digging. Find the last cut do a good sealed, undergound splice (electrical supply should have one). Re-run a new wire to the house. Good luck.
__________________
Old 10-18-2009, 02:29 PM   #23
savage
Member # 6162
sadly this is what i was thinking id have to do. luckily i know it aint real deep in the ground.
thanks for the advice guys!
Old 10-18-2009, 02:36 PM   #24
Billy_Goat
Billy_Goat's Avatar
Member # 1533
You could dig it all up and replace it but there are legal ways to get around it.
Go to Lowes/home depot and get a 6x6 plastic waterproof box, direct burial wire nuts/waterproof(blue), some caulk, and some direct burial NM cable the same size as you've got on the the rest of the run to span the distance.
Just replace the cut line.
Billy_Goat is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 02:43 PM   #25
jkruss
jkruss's Avatar
Member # 3071
You need a tool called a locater it connects to one end of the wire without energizing it.It sends signal through the wire and should get you close to the break by wathing the signal strenghth on the locater,it is an expensive tool and not sure if you could get one at atool rental place.But from the sound of it you should redo it.
__________________
Black Jeep
jkruss is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
