Security system problem - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Electrical & Lighting Tech Dept.
Old 01-25-2014, 11:03 AM   #1
ASSFROW
ASSFROW's Avatar
Member # 17518
Exclamation Security system problem
Ok, so I just went through the car wash and noticed a little red light lit on the dash. Got home pulled into the garage to work on it, shut off pulled out the manual to figure out what the light is. It is an indicator for the security system and says it comes on if you use the wrong key and the engine will shut off. The engine didn't shut off, but now it won't start with either key and the buttons on the remotes do nothing. There is a constant chiming when the door is open and all of the indicator lights come on when I put the key in the ignition, but it won't start. I have the battery unhooked hoping it will reset, but I'm not hopeful.
Does anyone have any idea what happened and how to fix it?
Thanks in advance,
Gary
__________________
What is wrong with stupid people? Never mind
ASSFROW is offline   Reply With Quote Quick reply to this message
Old 01-25-2014, 11:10 AM   #2
PhrogMech46
PhrogMech46's Avatar
Member # 10501
I'm just guessing here but if the battery trick doesn't work you may have to tow it to the dealership to pair the keys with the Jeep again.
__________________
The duty of a patriot is to protect his country from its government.-Thomas Paine
See Garage for Mods
PhrogMech46 is offline   Reply With Quote Quick reply to this message
Old 01-25-2014, 11:17 AM   #3
2Door
2Door's Avatar
Member # 44633
Something similar happened to mine. It essentially disabled the ignition. I pulled the security system fuse from the block under the hood, waited about 10 seconds and put it back. After that, the key fob worked again and the Jeep started when I tried it.
I should add, I tried both keys, neither worked, both in the ignition or the fobs
With the battery disconnected, it should take power away from that fuse long enough to reset it. Hope it works for ya
__________________
2011 Sahara Tan 2dr Rubicon
Rock Krawler Stock Mod w/ Fox Evolution 2.0's - 35 X 12.5 X 15" Maxxis Bighorns on Black Steel wheels - Rock Krawler track bars front and back - Poison Spyder Customs BFH front bumper w/ Brawler bar - Warn HS9500i winch w/ synthetic rope - Smittybilt Atlas Rear Bumper with tire carrier - Trail Head Deflators - Viair 440P Compressor
2Door is offline   Reply With Quote Quick reply to this message
Old 01-25-2014, 11:18 AM   #4
ASSFROW
ASSFROW's Avatar
Member # 17518
That's my fear, but I'm hoping someone might know something I don't(most people do).
__________________
Old 01-25-2014, 08:29 PM   #5
ASSFROW
ASSFROW's Avatar
Member # 17518
Well I left the battery disconnected while I installed my HID kit. When I hooked the battery back up the security system was fine, but the wipers went ape shit and after a few times starting and shutting the engine off they turned off.
__________________
Old 01-25-2014, 10:26 PM   #6
LeJerk
LeJerk's Avatar
Member # 20619
Did they they get your key mixed up with another Jeep at the car wash? Maybe the other guy is having the same problem right now.
LeJerk is offline   Reply With Quote Quick reply to this message
Old 01-25-2014, 10:27 PM   #7
LeJerk
LeJerk's Avatar
Member # 20619
Maybe get your battery checked? I remember a friends JK had electrical weirdness on start-up and his battery was dying.
Old 01-26-2014, 07:31 AM   #8
ASSFROW
ASSFROW's Avatar
Member # 17518
It was drive through car wash where they scrub the outside first, but I never got out. I did turn it off and on a few times while I was waiting, so maybe the battery is weak and made it act up. Thanks for the heads up I'll keep an eye on it.
I hate going to the car wash. I only went so I wouldn't have to work on a salt crusted Jeep with ice packed underneath. They have used so much salt on the roads that it took 3 days to be able to see the lines on the roads and it's like a dust storm on the highway from the salt dust.
__________________
Old 02-07-2014, 07:37 AM   #9
Jeepinwilson
Member # 19071
Mine just started having an issue with the small red light coming on and going off after about 20 minutes of driving the past couple of days. I am not sure what is going on, but it has yet to not start for me. It is really odd, because it comes on and then goes off, but at the same time the TMPS light comes on and goes off as well. Has yours stopped coming on or giving you issues yet?
Jeepinwilson is offline   Reply With Quote Quick reply to this message
Old 02-07-2014, 10:42 AM   #10
ASSFROW
ASSFROW's Avatar
Member # 17518
I haven't had a problem since I hooked the battery back up and I'm fortunate enough not to have TPMS.
__________________
Old 02-07-2014, 11:05 AM   #11
Grant211
Grant211's Avatar
Member # 92
Thanks in advance,
Gary
been discussed before....
http://www.jkowners.com/forum/showth...light=security
no real fix...
Grant211 is offline   Reply With Quote Quick reply to this message
Old 02-07-2014, 01:07 PM   #12
JKommuter
JKommuter's Avatar
Member # 7324
My jeep locked me out a couple of weeks ago, had to use the key in the door to get in. Once I opened the door the alarm activated (horn). I put the key in the ignition and turned it, alarm kept going, engine started and immediately died. Had the wife bring her key up to the office, put it in the ignition jeep started, and the alarm stopped. My key still wouldn't work. I replaced the battery in my key and everything was back to normal.
I know your seeing a different issue, but I can't help but wonder if the battery in you key is going dead.
JKommuter is offline   Reply With Quote Quick reply to this message
Old 02-07-2014, 04:52 PM   #13
ASSFROW
ASSFROW's Avatar
Member # 17518
no real fix...
My issue was different. The security system activated as if I had tried to hotwire or used the wrong key. It did what it was supposed to in that situation, but I was using the correct keys.
That is possible, but I don't think so. Neither of my keys would work and it initiated while it was running. Something freaked out the security system, I just don't know what. I was in the car wash, so maybe something got wet that shouldn't. It also hasn't happened again.
On another note my antenna took a beating and now my radio reception is bad, but nothing appears to be wrong with the antenna.
__________________
Old 02-06-2015, 08:48 AM   #14
AnthemAVM
Member # 6967
I have the same exact issue with my 2013, and might replace the battery before I take it to the dealer. Any update?
AnthemAVM is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
