Fresh Air Intake / Adjustable Snorkel - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Write Up Dept. (The Library)
Old 09-20-2009, 08:12 PM   #1
bodyguy
bodyguy's Avatar
Member # 1629
I wanted a snorkel but not what you normally see so I ran across a post on another web site and it sparked the idea. I have had the parts for probably 8 months or longer but haven't really had the time or a complete plan. Once finished I will be able to raise the height of the intake with a short piece of tube that will slip over the base and then put the breather on top.
Here are the parts I started with today. A sy-klone off highway breather/ rain cap and a 3" stainless elbow.
I had planned on scoping the area to drill but I got anxious and started drilling. Just as the pilot went through the sheet meat I remembered and stopped for a look, good thing. I knew the fresh air intake was on this side but didn't expect it to be completely in my way.
I moved the mount location a little further out , I think I like it better here and it turned out to be much easier.
I had to partially remove the fender (too lazy to remove the rock rail) and to do that you have to remove the windshield frame support.
You can see my almost screw up
Now that I had the exit location it was time to drill the cowl and fresh air trough. This turned out to be a pain since I had moved the exit location due to an oblong hole in the way. I didn't want to drill next to it and have to fill it in so I moved over and included it in the new hole. Kind of put things off a little but nothing a little more tubing and a tig cant fix.
You can see the hole that was in my way
__________________
bodyguy is offline   Reply With Quote Quick reply to this message
Old 09-20-2009, 08:17 PM   #2
bodyguy
bodyguy's Avatar
Member # 1629
Next I marked and drilled the fender hole
Bolted the fender back in place and mocked it all up
Now the fun part moving the battery and body contol module / power distribution box.
__________________
Old 09-20-2009, 08:30 PM   #3
Dr.Dirty
Member # 1569
Feedback: 21 reviews
Looks great man i like the low profile
Dr.Dirty is offline   Reply With Quote Quick reply to this message
Old 09-20-2009, 09:04 PM   #4
Goodwood
Goodwood's Avatar
Member # 5667
I have been toying with the homebrew snorkel idea. I am really liking your thinking on this one! Keep the pics coming! Where did you get the stainless elbow? I an guessing you can adjust the height by removing the top and adding a tube? Nice idea!
__________________
more wagging, less barking
Goodwood is offline   Reply With Quote Quick reply to this message
Old 09-21-2009, 05:31 AM   #5
riverzendz
riverzendz's Avatar
Member # 1678
Clever, good work!
Post up some more shots of the battery relocation and the rest of the install.
riverzendz is offline   Reply With Quote Quick reply to this message
Old 09-21-2009, 11:29 AM   #6
bodyguy
bodyguy's Avatar
Member # 1629
Originally Posted by riverzendz View Post
Clever, good work!
I have a few ideas on battery placement just trying to figure out the best one as far a access and cable length. I have to lengthen the intake duct and permanetely install it, then finish the air box.
__________________
Old 09-21-2009, 11:41 AM   #7
gold knight
gold knight's Avatar
Member # 1460
Very cool. Look forward to seeing the finished product. It really helps being a "bodyguy" during the oops moments huh? You can take it to yourself for repair, lol.
Make sure you send USMCDOC this way. He was contemplating a similar mod a few months back. I don't think he's done anything with it yet.
__________________
gold knight is offline   Reply With Quote Quick reply to this message
Old 09-21-2009, 12:30 PM   #8
PB Foot
Member # 1793
if you want bring it to me when you are done and I will bend up a hard intake tube from 3" exhaust pipe. or 2.5" if it is closer to factory size.
PB Foot is offline   Reply With Quote Quick reply to this message
Old 09-21-2009, 12:33 PM   #9
karnuvore
Member # 1688
Clever shit man. Love the low profile aspect.
karnuvore is offline   Reply With Quote Quick reply to this message
Old 09-21-2009, 01:01 PM   #10
joePILE
joePILE's Avatar
Member # 5518
thats awesome man, and i can easily see how the extender will work, freaking awesome
__________________
2008 BLACK Unlimited Sahara
and
joePILE is offline   Reply With Quote Quick reply to this message
Old 09-21-2009, 02:33 PM   #11
enigmaverse
enigmaverse's Avatar
Member # 4659
I am going to be watching this closely.... I was trying to do it without moving the battery, but your location is so simple, I was just looking under the hood, are you sure you need to move the battery? or is this simply to relocate the air box as well?
It look like if the wiring harness are slightly rerouted, you should be able to put a 90 out of hole and then work your way from there.... again just eyeballing it
__________________
Joe -
enigmaverse is offline   Reply With Quote Quick reply to this message
Old 09-21-2009, 02:37 PM   #12
SONIC
SONIC's Avatar
Member # 877
Very cool.
You shoudl put some sort of mount on the top of the windshield, so that in the case of a really deep crossing you can just hook up a piece of flexible tubing and mount the filter thing on top real quick.
__________________
-Doc Holiday
SONIC is offline   Reply With Quote Quick reply to this message
Old 09-21-2009, 03:07 PM   #13
tkob1060
tkob1060's Avatar
Member # 5021
hmm I could extend my Rr snorkel with that hahaha
__________________
tkob1060 is offline   Reply With Quote Quick reply to this message
Old 09-21-2009, 03:08 PM   #14
SONIC
SONIC's Avatar
Member # 877
Does that top piece have a filter in it? Are you going to bypass the stock filter?
__________________
-Doc Holiday
Old 09-22-2009, 07:03 PM   #15
DanNEBTD
Member # 5169
Subscribed . . . always wanted a HHMMV style CAI/Snorkel and this looks promising pending answers asked above
DanNEBTD is offline   Reply With Quote Quick reply to this message
Old 09-22-2009, 09:50 PM   #16
bodyguy
bodyguy's Avatar
Member # 1629
what oops moments? Those dont happen, I promise
I saw you put a link in his post, Thanks
I might take you up on that
Thanks guys, you never know how other will react when you start doing some off the wall chit.
The problem is routing the duct, not enough room between the hood and everything else. I was going to try and use the stock air box but I couldn't make enough room without some major changes, so now my head hurts from trying to get it to work the way I want and look decent.
Originally Posted by SONIC View Post
Very cool.
Thats not a bad idea
The top piece does not have a filter in it, its called a pre-cleaner but has no filter element in it. It has a turbine in it that is suppose to disperse debris before they make it to the filter. I bought it from Jeff Moredock at Sy-Klone.com. I am currently figuring out how I am going to built the air box, I will running a filter but no not the stock one.
Thanks guys for the positive feedback and ideas, I have a tendency to over think projects and reading these post makes me step back and take a look and question what I am doing.
__________________
Old 09-22-2009, 10:05 PM   #17
Goodysgotacuda
Goodysgotacuda's Avatar
Member # 4538
That ducting will kill airflow, be best to try and minimize it and stay as smooth as possible. cool idea!
__________________
Goodysgotacuda is offline   Reply With Quote Quick reply to this message
Old 09-23-2009, 04:56 AM   #18
bodyguy
bodyguy's Avatar
Member # 1629
The duct is smooth on the inside and when I am finished I should only have about 18 to 20 inches of it, and even less if PB Foot bends some 3" tube for me.
__________________
Old 09-23-2009, 06:51 AM   #19
PB Foot
Member # 1793
Talking
this project should really test the quality of the ADHD meds available today
I can bend up the pipe on the bender I have here at the shop or get some mandrel bent pieces and weld up something for you LMK
Old 09-23-2009, 08:12 AM   #20
missb
Member # 6097
Brilliant!
missb is offline   Reply With Quote Quick reply to this message
Old 09-23-2009, 05:50 PM   #21
bodyguy
bodyguy's Avatar
Member # 1629
Tell me about it
I think I am going to buy a tig so I can start doing my own aluminum and stainless welding. My mig has a spool gun attachment but I think I would rather have a tig. I have a friend of a friend doing the tig work for me right know, but thanks.
__________________
Old 09-25-2009, 06:53 AM   #22
PhilD
TrailDuty.com
PhilD's Avatar
Member # 143
Your beach parking permit is out of date
Nice work, looks like a lot of work though!
PhilD is offline   Reply With Quote Quick reply to this message
Old 09-25-2009, 10:26 PM   #23
bodyguy
bodyguy's Avatar
Member # 1629
Under cover beach patrol
Yeah getting everything to fit the way I want has been a chore.
I did get the upper duct back from the guy doing my TIG work for me. If I could just get that Snap-On tool box sold I could get me a Tig and do it myself. I dont like having someone else do work for me that I can do myself.
Hmm
__________________
Old 09-26-2009, 04:40 AM   #24
Dr.Dirty
Member # 1569
looks good man but somone stole your windshield
Old 09-26-2009, 11:48 AM   #25
edivebuddy
edivebuddy's Avatar
Member # 3217
Move just the battery, it will be easier.
edivebuddy is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
