Bigger Tires, do I really need new rims too? - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Community > JK General Discussion
Old 09-01-2009, 07:02 AM   #1
Rednroll
Member # 5787
My Jeep is pretty much stock right now, but my 1st real mod will probably be a 4" lift and then getting some bigger tires.
So I was looking at this thread at some of your before/after pics:
http://www.jkowners.com/forum/showthread.php?t=14002
I noticed everyone along with getting the larger tires also got new rims to put them on. Well, I got the Sahara package and in that package it comes with 18" Rims. They are listed as 18"x 7.5". So my question is, do I really have to get new Rims for the larger tires or did you guys do this just to make your Jeep look more customized? Or is their some other reason for needing to get new rims?
I kind of like the stock rims and paid extra for the 18" ones that come with the Sahara package, so I'm just wondering if I really need to change them if I go to a larger tire.
Rednroll is offline   Reply With Quote Quick reply to this message
Old 09-01-2009, 07:22 AM   #2
jeeperjkj
jeeperjkj's Avatar
Member # 4516
"Need"? No.
Should you? That's debatable.
Consider this before jumping in...
  • For the most part, 17" tires are going to be quite a bit cheaper than 18" tires.
  • You'll need 1.5" spacers if you go wider than 10.5" tire (I think that's a good rule of thumb on the width, but I might be corrected. Suffice it to say if you go to a 12.5" wide tire that you need the spacers to eliminate rub).
  • You'll get a bit better off road performance with minimal on road penalty going to 17" from 18" tires.
  • You'll get to find a nice set of wheels to compliment your Jeep tastes.
I'm sure there are more reasons, but that's a start.
__________________
jeeperjkj is offline   Reply With Quote Quick reply to this message
Old 09-01-2009, 05:46 PM   #3
Jayce113
Jayce113's Avatar
Member # 5514
I have the sahara as well. I actually took mine and got them blasted and powder coated. If you are going with a lift and wanna go with a 35" tire, your gonna have to get 1.5" wheel spaces to keep things from rubbing wrong. The 18" ers are gonna give you alot of rim to beat the heck out of on the trail through, bigger rim = less rubber ont he sides. You can do what I'm planning on doing get some $64 steel rims 16 or 17" and get the 35" tires lot more rubber and wont beat the crap out of the rims as much.
__________________
2007 RESCUE GREEN JEEP SAHARA
UNITED STATES AIR FORCE
Jayce113 is offline   Reply With Quote Quick reply to this message
Old 09-01-2009, 08:13 PM   #4
venom
venom's Avatar
Member # 146
I've been running my 35x12.50s on my stock 17" Rubi rims with 1.5" spacers for a looong time with no problems
you'll need spacers to goto a 12.50 tire but otherwise they work fine.
I 2-toned mine for looks, but that's it.
__________________
Originally Posted by My Wife
venom is offline   Reply With Quote Quick reply to this message
Old 09-01-2009, 09:52 PM   #5
jtphoto JK
jtphoto JK's Avatar
Member # 1930
Was cheaper for me to buy 5 new 16" wheels and tires then to buy the same tire alone in 18". Let alone have to spend $300 on wheel spacers.
__________________
Jeff _(OllllllO)_
08 Black and Khaki JK Sahara Unlimited, Dual Tops, MyGig, Tow pkg, Trax-Lok Rear Diff,
Mods -- 3.5" Rock Krawler front springs, 2.5 TerraFlex BB rear, 37x12.50x17 Pitbull Rockers on ProComp 7069, AEV Premium front bumper, Smittybilt X2O 12K Comp winch.
jtphoto JK is offline   Reply With Quote Quick reply to this message
Old 09-03-2009, 03:17 AM   #6
OneCav
Member # 4943
Agreed, don't bother with wheel spacers. Just get an aftermarket wheel with a better backspacing so you can run wider, and taller tires without needing wheel spacers.
OneCav is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
