Rear Quarter Cutting - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 04-19-2017, 05:13 AM Thread Starter
j-rod17's Avatar
Show me yours!
I am to the point of going to need to cut my corner armor and body. would like to see some of your cuts and how you did it.
This one has been some inspiration lately
Keep in mind I cannot comp cut as I do drive on road and keep it mostly legal. WV requires flares and tire coverage. LAME!
so show me what ya got
2008 JKU: continual work in progress
j-rod17 is offline
post #2 of 5 Old 04-19-2017, 07:05 AM
Originally Posted by j-rod17 View Post
Show me yours!
Do you know which armor combo is on that black JK you posted?
Metal Cloak does make the removable fenders w rear armor. With the rear fenders off (which just take a few allen key bolts), it looks/functions like a comp cut basically.
AdrockTT is offline
post #3 of 5 Old 04-19-2017, 07:26 AM
Thats basically a comp cut in the photo and if you look at it from the side view it is a huge hole in the side with a lot of space forward of the tire. Looks like about a 8-10" rear stretch on that rig. I can't post photos on this forum but mine can be seen on my build thread on jkfreaks.com I have several photos of the jeep with cuts and body panels removed.
If you can I would cut as much of the side off as you can, like leave only about 4" of the body below the top rail where the top mounts then build some side corners to match your wheel hole. Build some removable fenders so you have the clearance for wheeling if you want. Best if you can do it in 3/16" aluminum to save the weight or you can buy steel blanks from river raider. Add the rub rail like in the photo to get more strength along the side.
New to jeeps, check this link
post #4 of 5 Old 04-19-2017, 07:39 AM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
Mine is heavily detailed here:
Ole Tink - RCO 2 Door Build
The corners I have are available from Crawler Conceptz now. They have a bit of a lead time, but they are producing them in a 3" and 6" stretch version.
RiverCityOffroad is offline
post #5 of 5 Old 04-19-2017, 09:14 AM Thread Starter
j-rod17's Avatar
Thanks for the info so far guys. Gives me some reading material this evening.
I do have a set of corner armor already. They are original EVO blanks. they have been powder coated already too. I planned to have the rub rain installed and cut the skins to match the tub.
honestly as far as flares I was going to try and massage a set of stock flares (cut to fit) and install with the push in body clips so I can take on and off very easily. (may not be possible but was gonna try)
j-rod17 is offline
