New Heavy Duty ORO Tie Rod (& axle disaster) - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 07-13-2009, 03:15 PM Thread Starter
4x4LOYR's Avatar
Installed a new Heavy Duty ORO Tie Rod on Saturday, and then immediately went out and destroyed the U-joint assembly on the front driver's side of my axle. I got about a total of 12 miles on the new Tie Rod; but, so far I love it. I had a small shimmy at a certain speed, and it seems to be a lot less now. The steering just seems more firm (of course, I still have very few miles on it since the JK is now on jack-stands (again)).
So, the install of the new ORO *straight* heavy duty tie rod:
The old tie rod removed:
The new bracket for the new tie rod (driver side)
The new bracket & tie rod (passenger side)
The new bracket & tie rod (driver side)
Adjusting the "Toe"
New Tie Rod installed
And, the axle shaft U-joint disaster:
The hill that did me in (the photo does not do it justice -- I was the only one *smart* enough to attempt to climb up it):
Ty....
4x4LOYR is offline
post #2 of 19 Old 07-13-2009, 03:48 PM
Mr.RonGilbert's Avatar
Great write up. Sucks a biggun' about the axle though. I need to swap out my tie rod as well, mine is bent.
Any clue on the cause of the axle failure? Usual suspect coughskinnypedalcoughcough or something else?
Mr.RonGilbert is offline
post #3 of 19 Old 07-13-2009, 04:18 PM Thread Starter
4x4LOYR's Avatar
Yeah, my tie rod was way bent and wavy (damn rocks). This new straight one is great (so far).
Oh, I was goofing off trying to make it up the hill; just couldn't get myself over a couple of rocks, and well, I had some pretty good RPMs spinning . . . a bit too much skinny pedal, yes.
The new RCV Performance axle shafts have been ordered and are already on their way. Getting away from them ol' U-joints (being that this is the second time I've blown out that assembly).
4x4LOYR is offline
post #4 of 19 Old 07-13-2009, 05:57 PM
StubEXrube's Avatar
You sure that you didn't lose a u-joint cap, causing this failure?
StubEXrube is offline
post #5 of 19 Old 07-13-2009, 07:27 PM
Get some good pix of the new setup... .sounds like something that folks would be interested in.
post #6 of 19 Old 07-13-2009, 07:45 PM
RUDY850's Avatar
Got a link for more infomation on the tierod. looks good
RK 3.5 LIFT/RRD SHOCKS/FRONT CONTROL ARMS/DRAG LINK/TRACK BAR/REAR BRAKE HOSES/COOPER 295-75-17 STT JEEPERMAN FRONT BUMPER SUPERWINCH EPI9 JKS LOWER TRACK BAR BRACES/DISCONNECTS CRAGAR WHEELS SOFT 8 SYNERGY UPPER TRACK BAR BRACES RR SKID PLATES BENCHMARK DESIGNS EVAP SKID
RUDY850 is offline
post #7 of 19 Old 07-14-2009, 09:19 AM Thread Starter
4x4LOYR's Avatar
I'm not sure. Someone with me found two caps, and some metal chunks, but that was about it. Hard to tell; pretty sure I was on the gas more than I should have.
4x4LOYR is offline
post #8 of 19 Old 07-14-2009, 09:22 AM Thread Starter
4x4LOYR's Avatar
I ordered the tie rod from Kevin's Off Road, but when it showed up it was labeled as an ORO brand. Both have it on their websites. I'd add a link but I'm current on my PDA; will try to do so later.
4x4LOYR is offline
post #9 of 19 Old 07-14-2009, 09:37 AM
MR LIKA's Avatar
Remember that it's ok to take the Girl Scout bypass every once in a while
JKUS Sort of
MR LIKA is offline
post #10 of 19 Old 07-14-2009, 10:38 AM Thread Starter
4x4LOYR's Avatar
Yeah, yeah, yeah. But only on trails where everyone else has Dana 60's. Stupid rocks.
4x4LOYR is offline
post #11 of 19 Old 07-14-2009, 10:39 AM Thread Starter
4x4LOYR's Avatar
4x4LOYR is offline
post #12 of 19 Old 07-14-2009, 10:47 AM
Ogie's Avatar
Nice kit but it's more expensive than Poly's.
Vidi, vici, veni
2008 Jeep JK Wrangler Rubicon Unlimited
Ogie is offline
post #13 of 19 Old 07-14-2009, 12:46 PM Thread Starter
4x4LOYR's Avatar
Yes, however, Poly's is not straight . . .
Poly Performance Jeep JK Chromoly Tie Rod
Description:
•Heavy duty tie rod for Jeep JK Wranglers
Bent similar to factory bar to clear sway bar mounts
•Made from 13/8" 4130 Chromoly and Heat Treated for maximum strength
•Poly Performance Double Adjuster Sleeve: allows adjustment of tie rod length without removing it from the vehicle
•Strongest Jeep JK Tie Rod on the market!
•Suspension components feature an abrasive resistant powder coat finish for maximum durability and corrosion resistance
•100% bolt on components assures an easy, trouble free installation with the use of basic hand tools
Includes:
•(2) Heavy Duty Tie Rod Ends
•(2) Castle Nuts and Cotter Pins
•(1) Heat Treated Chromoly Tie Rod
•(2) Grade 8 Pinch Bolts & Hardware
•(2) Poly Performance Double Adjuster Sleeve
What I liked about the one that I got is that it raises the tie rod up a bit (a bit more clearance in the front sounded like a good idea to me).
4x4LOYR is offline
post #14 of 19 Old 07-14-2009, 12:55 PM
Ogie's Avatar
So? The sucker is strong and short of driving off a cliff, it's not going to get tweaked.
By one whole inch. Everytime I smacked my tie rod into a rock, one inch would have made no difference.
Don't get me wrong, Ty, it's a nice tie rod. I just think Poly's a slightly better deal.
Vidi, vici, veni
Ogie is offline
post #15 of 19 Old 07-14-2009, 01:08 PM
rubirobv's Avatar
I saw that. Couldn't hurt to get the tie rod up. Just wonder if it's enough to make a difference. I guess you'll tell us. This is the first I've seen where the tie rod is raised up. I wonder if you're going to smash the steering stabilizer on the drag link with the tie rod raised up some?
rubirobv is offline
post #16 of 19 Old 07-14-2009, 04:27 PM
Riverkid's Avatar
Says the guy with 37's all locked up... He definitely tried at BBFF...
Riverkid is offline
post #17 of 19 Old 07-15-2009, 05:24 AM
Slow and Low
Co4Lo's Avatar
Every inch of clearance is valuable. And most importantly, the fact that it's straight makes it adjustable without the use of sleeves, and it will never rotate under load. The slightest bit of rotation will cause a bent tie rod to have noticeable slop at the steering wheel.
Knowing ORO, it's probably worth the money. They are not as popular as some of the bigger players, but they build some quaity stuff.
Co4Lo is offline
post #18 of 19 Old 07-16-2009, 01:37 PM Thread Starter
4x4LOYR's Avatar
Yeah, I really like the tie rod so far, plus the little bit of more clearance, and for whatever reason, I dig the fact that it is *straight* . . . easy to adjust, and then tighten down.
And maybe more importantly, the service at ORO is great! I didn't even buy this directly from ORO, but rather, from Kevin's Off Road (KOR). Well, I contacted Kevin’s, and through them, I got in touch with ORO, who is really helping me out. ORO makes a bracket that accommodates upgraded axle shafts, and since I will now have upgraded axle shafts, they have sent me out the new, improved brackets. And, they sent them overnight to me because I am hoping to install the new shafts this weekend (I paid for the overnight shipping), but they are covering the return postage for the slightly used original brackets.
Good people to work with.
4x4LOYR is offline
post #19 of 19 Old 07-16-2009, 10:28 PM
b1pig's Avatar
dont they have Longfield axles now for the JK? wonder how much stronger they are... just skimmed over it in one of the mags yesterday....
steering looks pretty decent. i guess that is to give it a little more leverage and cut down on bending the tierod?
'15 Ram 1500, '15 Challenger SXT
2008 Kawasaki KLR650
b1pig is offline
