07 and 08 JK - Antitheft System - Engine No Crank/No Start Condition - July 08 - JKowners.com : Jeep Wrangler JK Forum
post #1 of 49 Old 11-10-2008, 12:19 PM Thread Starter
Administrator
Lance's Avatar
NUMBER: 08-007-08 REV. A
GROUP: Electrical
DATE: July 04,2008
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-007-08, DATED MARCH 04, 2008. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT REVISIONS.
DO NOT ORDER PART NUMBER 05026070AP UNTIL JULY 21, 2008. ALL OTHER PART NUMBERS ARE AVAILABLE NOW.
SUBJECT:
No Engine Crank Or No Engine Start Due To Electronic Lockup Of The WCM / SKREEM
OVERVIEW:
This bulletin involves the replacement of the Wireless Control Module (WCM), and if equipped, the replacement of the Electric Steering Column Lock (ELV). The WCM is also referred to as the Sentry Key Remote Entry Module (SKREEM).
MODELS:
2007 - 2008 (JK) Wrangler
NOTE :This bulletin applies to vehicles built on or before May 05, 2008 (MDH 0505XX).
SYMPTOM/CONDITION:
The customer will experience a no engine crank AND a no engine start condition. Also, the remote keyless entry (RKE) system will not operate. This condition may be due to an electrostatic discharge (ESD) from the ignition key into the Wireless Control Module (WCM), causing the WCM to electronically lockup. This condition may occur more frequently in dry and/or cold weather conditions where a sufficient electrostatic charge is more easily produced. This condition is corrected by the replacement of the WCM.
Lance is offline
post #2 of 49 Old 11-30-2008, 05:44 PM
rooster's Avatar
Thanks for posting Lance.
rooster is offline
post #3 of 49 Old 05-17-2009, 01:00 PM
Lance,
Thanks for posting this. My 07 Rubi did this last week, I had no idea what was going on. I called the dealer, they did not mention anything about a TSB being issued, in fact they didn't even have a fix or a suggestion about a fix. They wanted me to have it towed to the dealer for diagnosis, which I could have. Before I did that, however, I tried the battery unhook just on a whim. That reset the module, I guess, 'cause everything works again. I wonder if it is going to happen again...if it does, I guess I'll have it towed in then so they can see what is happening. I don't know if they can tell if the module is bad unless nothing is working.
07 Jeep Green 2 door Rubicon; OME Std suspension; 33" BFG KM2; Shrockworks stubby front, Expedition One rear bumpers, JKS adj trackbars f/r, Poly HD tie rod, Moog TRE on drag link.
glwood is offline
post #4 of 49 Old 05-18-2009, 12:54 PM
jdrogers's Avatar
If it happens again you do want to take it in so they can replace the module. From what I understand the new module is not susceptible to electro static discharge like the original one.
2007 Stone White Rubicon
jdrogers is offline
post #5 of 49 Old 05-22-2009, 09:09 AM
In your opinion, would it be worth scheduling a service visit based on the fact that it happened once already, even though everything is working now?
glwood is offline
post #6 of 49 Old 03-03-2010, 11:31 AM
rjmcam's Avatar
Glad to find this- I had the WCM replaced and it has happened again... Do not like the wife being stranded in a parking lot...
Jeep is gone
rjmcam is offline
post #7 of 49 Old 03-15-2010, 07:32 AM
Firefighter_EMT's Avatar
I had it happen and they said that the skreem had locked out but that it had just lost its code... nothing about a recall thanks ill def go have a talk with them.. damn stealerships
Nice one Codd. Why dont you go have a Crainal Anal Inversion and call me tomorrow?
Thanks to people like you I have job security!
Why no officer this is not a potato launcher. Potato launchers are illegal. Why this, this is a Yam launcher!
Firefighter_EMT is offline
post #8 of 49 Old 03-15-2010, 07:35 AM
Dr.Dirty's Avatar
Feedback: 21 reviews
mine does it all the time but because it isnt a recall jeep said tuff shit
www.jeepasylum.com
Dr.Dirty is offline
post #9 of 49 Old 03-20-2010, 11:02 AM
Krunchytaco's Avatar
Is this on our dime to have this fixed?
My 07 does this weekly!
Krunchytaco is offline
post #10 of 49 Old 10-18-2010, 07:18 AM
If you have the lifetime warranty still it should be covered by that. If you are not under warranty (like me). Then just keep a fuse puller in your glovebox and pull M13 out of the fusebox for 30 seconds if it happens to you.
Mine has done it once in the three years I've bought it.
2007 Rescue Green 2-door
A few mods here and there
jgkjeep is offline
post #11 of 49 Old 10-29-2010, 06:37 AM
Diver's Avatar
I just came across this post, and wish I would have found it sooner.
I had this happen to me a few Fridays ago after work. Had it towed.
The dealership said they fixed it, stating "it was an issue with the key losing programming" I picked up jeep Saturday, drove fine all day Sunday. Go to start car for work Monday and same issue. Made dealership tow it on thier dime. They took a day and a half to say it was the same/similar issue. Fix was no charge(niether was tow).
Last service invoice shows:
Job#1 68001702-AA Key Blank
So I called service and talked to the clown(service manager) who was handling my issue. He stated that he replaced the WCM the first time. The 2nd he had to replace the chip in main key that was used (I left both keys and told him to make sure they both work). So far its working without issue.
Is there another alternative to pulling the fuse, if it happens again?
Diver is offline
post #12 of 49 Old 10-29-2010, 06:49 AM
jacktuttle's Avatar
Exclamation the lifetime warranty
Keep in mind that the " lifetime warranty " is on the power train only. Also I have been warned by the service manager at my stealership that Chrysler is checking records to insure you have preformed all of the "Required maintenance" and voiding the warranty if you have failed to do so.
jacktuttle is offline
post #13 of 49 Old 11-18-2010, 05:23 PM
drew's Avatar
FN POS
Happened to me today. Remote wouldn't work so I opened it with the key. Alarm went off and wouldn't stop so I disconnected the battery. Finally got it to start and went home for lunch with all the idiot lights on. After lunch, tried to start it and nothing. Disconnected and reconnected the battery, tried all the remote buttons on both keys, nothing. Called the tow truck and went off to the stealership. $100 to look at it and then $300+ for what they called a Win (?) module to get the POS to recognize the key. Then maybe they can find out if there is more "damage".
Glad I found this thread about the TSB, maybe it will save me some $.
Wanna drop a SBC and a Warn OD in my '48 Willys and use it for a DD. At least I could fix it.
FN computers...
drew is offline
post #14 of 49 Old 11-19-2010, 01:31 PM
rjmcam's Avatar
FN computers...
This was all covered under warranty for me- twice already
Jeep is gone
rjmcam is offline
post #15 of 49 Old 12-08-2010, 09:14 AM
I had this happen two nights ago, on my 2008 JK Unlimited, which was made in January 2008.
Of course it did it at night in the Publix parking lot, when it's about 25 degrees. I googled the problem on my phone, and found the TSB, and the one I read mentioned pulling the IOD fuse, with the key removed, waiting 30 seconds, then replacing it. I tried that twice, and no luck.
I had to call my Brother up there, since I had no 10mm or 12mm to disconnect the negative cable.
We did that, and when we reconnected it, the horn chirped, which means the computer thinks the alarm was tripped before the battery was disconnected.
That got it running just like normal, and after 2 days, no signs of it again.
I brought it to the local dealership to have them check it out, since I don't fancy it happening again. Of course, after 3 hours waiting, and likely because I disconnected the battery, no codes were stored in the ECU, and they couldn't duplicate it. Of course if no codes were stored, how did it know to chirp the horn when it was reconnected? Hmmm.....
Anywho, I figure if it does it again, I call the roadside service #, and have them tow it, so they can actually see the failure.
I tried mentioning the TSB to the Service Advisor, but like most, they blow off any suggestion the customer gives, and won't do squat if they can't replicate the issue.
TripleJackInGA is offline
post #16 of 49 Old 01-06-2011, 08:48 AM
jacktuttle's Avatar
Unless its Customer Pay
Anyhow, I figure if it does it again, I call the roadside service #, and have them tow it, so they can actually see the failure.
Yes, I'm just guessing that unless it is a customer pay, with out a code to report they would have trouble getting the factory to cover it.... Not that they go out of the way to do anything much for us.....
Mine did this yesterday for the first time. I got a little red light above the temp gage that made me think something was running hot, but a quick check of the owners manual showed it to be the alarm sentry. The jeep would not start or unlock the doors. I disconnected the battery cable for a few seconds and all is fine now. (Other than the fact that it happened at all)
post #17 of 49 Old 01-07-2011, 08:06 PM
ibjammin's Avatar
I had a problem today in my 2010 with 13000 miles like this on the way to work this morning I stoped at the gas station to get some things it ran great and when I came out and tried to start it it was dead? I called service and then roadside assistance and they sent a tow truck while I was waiting I remembered to pull the superchips tune and check for any DTC codes I pulled a code that said loss of signal to the security module of coarse they couldn't get to it today so hopefully tomarrow I will find out what the problem is? They even had the balls to say a rental car was no covered and I said WHAT you have got to be kidding I bought a new car thinking it would be dependable I already lost a day of work and 400 bucks! They finally covered the rental car. I was thinking about disconecting the battery I should of tried it I would hate to think how much it would suck if this happend out on the trail?
ibjammin is offline
post #18 of 49 Old 01-10-2011, 11:16 AM
Squirrel Killer's Avatar
Send a message via Yahoo to Squirrel Killer
This is what happened to mine a couple weeks ago. Stuck in Walgreens parking lot for 4 hours. Called roadside #, they came and towed it. 3 days later got it back. Stealership said they replaced the WCM and reprogrammed both my keys. Hasnt happened since. By the way, it was about -cold as shit degrees outside. I didnt pay a dime for any of it. 2008 with 30k
2013 Commando Green Sport S
TF 2.5", RK Control Arms, Gobi Stealth Rack, Level 8 Tracker Pro on 35's, TruckLite LEDs, TrailDash
-Sean
Squirrel Killer is offline
post #19 of 49 Old 01-13-2011, 09:31 AM
DARWIN's Avatar
i'm having a similar problem with my 08 rubicon. except all the lights and chimes will go off while i'm driving, then when its turned off it will not restart. and again all the idiot lights will blink when the key is turned on. has this happened to anyone else with the wireless control module problem?
DARWIN is offline
post #20 of 49 Old 01-13-2011, 10:23 AM
jacktuttle's Avatar
Post happened to anyone else
I had the red light over the temp gage light up and my TPS low tire waning was on. As soon as I turned off the jeep everything was dead until I disconnected the battery for a few seconds. After the one time, no more issues, but it was a very cold day when it happened. We don't' have many of those in Southern California.
post #21 of 49 Old 01-13-2011, 10:31 AM
DARWIN's Avatar
its been happening more frequently lately but our temps in utah have been in the low single digits in the morning and 30's in the day. it almost seems like it may be a different problem with every light and chime going off at once
DARWIN is offline
post #22 of 49 Old 01-13-2011, 10:41 AM
jacktuttle's Avatar
Question different problem
Does disconnecting the battery get you going each time?
post #23 of 49 Old 01-14-2011, 04:22 PM
DARWIN's Avatar
the first couple of times disconnecting the battery would allow it to start. the last time it happened disconnecting the battery didn't work, and i had to leave the jeep at work. the next day the battery was completely dead. after recharging the battery it started right up and has run for a few days just fine. the more i read about it the more everything points to the TIPM.
DARWIN is offline
post #24 of 49 Old 01-14-2011, 07:21 PM
jacktuttle's Avatar
Dealer
Have you talked to the dealer yet? Even if you have to pay them, there is a point when you just want your jeep to work.
post #25 of 49 Old 01-23-2011, 12:31 PM
09 jk rubicon
i have had dead battery issuse n past ended up putting red top in. Now it was towed to dealer for no crank.Sent service bullition with jeep.waiting to hear from dealer monday.
rednekexprez is offline
You may not post new threads
