No spare rear rack. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 04-01-2017, 10:12 PM Thread Starter
akpostal's Avatar
No spare rear rack.
Just put this together. Lined out by Jeff Scherb.
Still waiting on my morryde hinges to mount the third bracket.
Still need to bolt in 3 ammo cans and an action Packer for a small kitchen, the cooler will be strapped down. Im going to need a step stool to get in the cooler while its up there and that can get bungeed to the cooler.
2014 JK Sport Anvil auto
COI
akpostal is offline
post #2 of 12 Old 04-02-2017, 06:11 AM
ಠ_ಠ
rack - shrack ; I dig your decal!
I have him on my jeep someplace for folks to know how we feel about them, too...
edit: I did check the rack out and it's nice. Personally, I'd find a good Krylon that didn't require primer/ had it mixed-in and "flat black-it ",but it's just my opinion. Aluminum saves weight ; couldn't you also have a rectangle of expanded aluminum mesh from McMaster-Carr riveted to the floor of your basket- or eye bolted so it'd be removable - so stuff smaller than a softball won't fall thru the bottom ?
Lastly , 'think heavier duty /reinforced hinges maybe needed with this if your Offroading it and carrying that type weight , I'd wonder ?
ºlllllllº '11 JKUs
lllllll '95 XJ
post #3 of 12 Old 04-02-2017, 03:03 PM Thread Starter
akpostal's Avatar
I have morryde heavy duty hinges on order. Ill be adding a third bracket once to the hinges once they're on.
Heaviest thing on the rack will be my food cooler and that will be centered. Recovery gear will be in one of the ammo cans or quick fist to the rack, first aid kit will be another, not sure what is going in the third can.
COI
akpostal is offline
post #4 of 12 Old 04-02-2017, 04:21 PM Thread Starter
akpostal's Avatar
Should be less then a spare tire. Heaviest thing will be the food cooler and that will be centered and wont always be up there. Will be carrying a strap D rings, an ax bow saw and shovel, and first aid kit. I need to dig my rafting stuff out of the snow to find my cooking gear. I plan on a Action Packer with a catering stove, a cast iron pan, cutlery, basically a small kitchen.
Put the Packer and cans up there to measure for the cooler.
Im short by about an inch for the cooler. If I remove the upper rail I can move the Packer and cans out and should have enough room for my old ***** Coleman cooler.
COI
akpostal is offline
post #5 of 12 Old 04-02-2017, 06:27 PM Thread Starter
akpostal's Avatar
Pulled the rail and mounted the Action Packer, Ill bolt the cans in tomorrow. Should be plenty of room for my cooler.
COI
akpostal is offline
post #6 of 12 Old 04-03-2017, 09:28 PM Thread Starter
akpostal's Avatar
Cans bolted in.
COI
akpostal is offline
post #7 of 12 Old 04-03-2017, 11:14 PM
ಠ_ಠ
nice! That is very versatile.
ºlllllllº '11 JKUs
lllllll '95 XJ
post #8 of 12 Old 04-10-2017, 06:48 PM Thread Starter
akpostal's Avatar
Strapped the cooler in to test fit. This cooler is older then I am, I have a new one of these on the way. Will be mounting a CB antenna behind it, the cooler wont always be on there.
COI
akpostal is offline
post #9 of 12 Old 04-11-2017, 05:55 PM Thread Starter
akpostal's Avatar
I have a Front Runner tailgate table I have yet to install, but with my back it seems low for cooking and prep.
The backside of the rack could either have a table clip on or be mounted and hinged. If I had a table off the rack I could use the FR table for a staging area for food or drink prep, with the upper table for actual cooking.
COI
akpostal is offline
post #10 of 12 Old 04-12-2017, 03:24 PM Thread Starter
akpostal's Avatar
New cooler arrived. perfect fit. I wanted a Ozark Trail cooler but measurements dint look like it would fit.
COI
akpostal is offline
post #11 of 12 Old 04-20-2017, 08:05 PM Thread Starter
akpostal's Avatar
Finally got the Morryde HD hinges installed. They dont open as wide as the stock hinges do, the rear glass rubs on the rack.
Im gonna have to push the rack out before putting in the third bracket for the rack.
COI
akpostal is offline
post #12 of 12 Old 04-28-2017, 08:38 PM Thread Starter
akpostal's Avatar
Moved the rack out a bit to clear the glass. Added bolts to the ammo cans to lock them down and keep from rattling.
Finally added the third bracket to the HD hinges.
I want to add a 2 locking sliding shelves to the rack. On the passenger side it would slide out and on the drivers side it would slide in to be used when the gate is open.
COI
akpostal is offline
