Detroit Soft Locker versus Eaton E-Locker? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 08-17-2010, 03:10 AM Thread Starter
Actually, it looks like Eaton and Detroit are both made by Eaton, but the real question I'm wondering is what if any is the difference between a soft locker and an e-locker? I know the e- in e-locker stands for electric locker (in contrast to an air locker or mechanically actuated locker) but the description I've seen of the soft locker is that its passive instead of selectable by the driver. Is this correct? And based on that, does anyone have any feedback one way or the other? I'm just trying to determine which would suit my lifestyle which is daily driver plus regular offroading (nothing too extreme, still sitting stock).
jake_blue is offline
post #2 of 13 Old 08-17-2010, 04:43 AM
Prope's Avatar
The detroit will lock whenever power is applied to it and then unlock when there is no load. The e-locker locks fully when you push a button and unlocks when you push it again.
'08 Unlimited Sahara - Hemi -
Fenders & Rockers -
Prope is offline
post #3 of 13 Old 08-17-2010, 06:16 AM
If you are running an automatic and put a detroit in the rear it will be unnoticable as long as you don't get on the gas during sharp turns. If I was doing it over again I would get a detroit for my rear.
2007 Rescue Green 2-door
A few mods here and there
jgkjeep is offline
post #4 of 13 Old 08-17-2010, 08:51 AM
desert dog's Avatar
I'm running both in 2 jeeps. E-locker in the rear of my JK and TJ. Detroit Locker in the front of my JK with selectable hubs and in the front of my TJ without selectable locking hubs. I was running Detroits in my old Suburban too, which I just sold.
Remember, all Detroit lockers are "soft lockers" now, and they do behave a little better than the Detroits of old. The Detroit requires no switches, electric devices, air, or input of any kind. It does its own thing; fulling locking the axle when needed, and unbinding during turns (but not always in the dirt or on slippery surfaces like icy or wet pavement).
My thoughts on the Detroit in the front: Absolutely awesome off-road, I very rarely engage my rear locker anymore. Your ability to make tight maneuvers off-road is not diminished at all. Some claim that they can't feel it up there on the street, but that has NOT been my experience. With the manual hubs on my JK, its not an issue. But on my TJ, you can feel it on the street while making tight turns - my wife will not even drive the TJ anymore.
My thoughts on the Detroit in the rear: Once again, good off-road, but it does slightly limit maneuverability in tight spots. For mud bogging, sand, rock climbs, and most trails it is OK, but it kind of sucks in the technical stuff. I don't think that there is anything stronger and maintenance free you can use than a Detroit. In the rear, the Detroit is fine on the street. It will push a little bit when going into a turn, but really not that bad. The rear detroit in my Suburban was flat-out DANGEROUS on icy roads. If you live in a place with heavy winters, I would consider a selectable in the rear too.
Eaton e-locker: I have wheeled mine in two vehicles over the toughest trails in the west, including the hammers and have never had an issue. Nor have I ever seen an issue with anyone else's Eaton e-locker (and a lot of folks are running them now). If you do the research, you will find that about 99% of people who have them are happy with them, and 99% of people who don't like them do not have them. The design is not as beefy as an ARB, but they seem to be more trouble-free IME. The only drawback to the e-locker is that is takes several feet more than the ARB for the locker to engage/disengage. If I wanted to run on-board air, I would get the ARB. But since I had no desire to go with an air system on my current 2 builds, I went Eaton e-locker.
desert dog is offline
post #5 of 13 Old 08-17-2010, 01:31 PM
All detroits are softlockers only if they do not have C-Clips
ccwbrd is offline
post #6 of 13 Old 08-17-2010, 05:11 PM Thread Starter
Loads of good info - thanks to all for your feedback!
post #7 of 13 Old 08-17-2010, 05:21 PM
JKSteve's Avatar
Full carrier auto lockers are great, seamless with an auto and a longer wheelbase.
LJ Rubicon
JKSteve is offline
post #8 of 13 Old 08-18-2010, 02:27 AM Thread Starter
Good point, I guess it would have helped to provide a little info about the intended vehicle. This is a 2008 Unlimited 4-dr with an automatic, so it is the long wheelbase and it sounds like auto would be preferred to stick in this instance.
post #9 of 13 Old 08-18-2010, 08:27 AM
redx08's Avatar
I have a 4 door 08 jk unlimited with an auto and a detroit in the rear. You barely know its there. We don't have ice or snow, so I have no worries with that. My wife drove my jeep before the detroit and after the detroit was installed, and she never knew the difference in driving on the street. She hates driving the thing, so if there was any difference I would hear about it.
08 jk unlimited X
1 ton axles
39.5 Iroks
redx08 is offline
post #10 of 13 Old 08-18-2010, 10:27 AM Thread Starter
So it sounds like the concensus is that a Detroit in the rear would be unnoticable in standard conditions yet provide the positive traction desired and even in the front it would be useful since it would only be engaged when in 4WD anyways. If this is the case, I could skip selectable locking and let this locker just do its thing! Unless there's some negative I'm overlooking.
post #11 of 13 Old 08-18-2010, 10:56 AM
Prope's Avatar
Turning on the trail with both front & rear locked is kinda a PITA unless you have an atlas.
Fenders & Rockers -
Prope is offline
post #12 of 13 Old 08-18-2010, 11:58 AM
Dynatrac's Avatar
Great info for the OP. I agree with your assessment of the Suburban in the ice. Handling would be a little better if you had a Sof-Locker but it's still not a great idea for rigs that see a lot of time on icy roads.
Dynatrac is offline
post #13 of 13 Old 08-18-2010, 01:05 PM
redx08's Avatar
Agree you will not be able to make as tight as turns, but where i wheel we don't have switchbacks or alot of tight turns. Don't know about OP.
08 jk unlimited X
1 ton axles
39.5 Iroks
redx08 is offline
