Jku Half door build - Page 2 - JKowners.com : Jeep Wrangler JK Forum
 27Likes
post #26 of 122 Old 11-20-2016, 11:20 AM
Wow! Looks good so far. Keep up the great work!
08 JKU 6.0 LC8 6L80 Atlas 2 37" ridge grapplers on vapor pro 2 beadlocks, prorock 44,rcv's arb front. rock jock 60 rear 40spline shafts,arb 5.13's and a bunch of other stuff
89yjon is offline
post #27 of 122 Old 11-20-2016, 12:28 PM Thread Starter
pvanweelden's Avatar
Thank you!
Sent from my SM-G930V using Tapatalk
pvanweelden is offline
post #28 of 122 Old 11-20-2016, 05:21 PM
Ya had it all good to go, and then you went and changed it. Sometimes perfection sucks doesn't it?
Unrelated question. What plasma table do use?
Kevin
gt1guy is offline
post #29 of 122 Old 11-20-2016, 06:49 PM Thread Starter
Thanks, lol, I really can't even believe it myself, that I was all good to go with the bestop uppers, but I couldn't pass up getting the factory uppers.
I don't own the table, I met the owner thru a mutual friend. It is a Burntable 4x5 with hypertherm 65. It is awesome to be able to draw something up and watch it get cut out. Makes my switch of uppers not such a big deal at all
post #30 of 122 Old 11-21-2016, 07:57 PM Thread Starter
Doing a little bending tonight
post #31 of 122 Old 11-23-2016, 10:44 PM Thread Starter
A little more bending
Handle mounts and cable mounts
And countersinking driver side hinges
Tapcola- that sucks about your jeep, I hope you and yours are ok man.
Chuck- I made this after reading about your accident and realizing I did way too much free hand cutting and grinding
post #32 of 122 Old 11-24-2016, 01:42 AM
ChuckTheRipper's Avatar
Dude... that is awesome. Glad my misfortunes have made a positive impact on you! - no sarcasm intended.
Doors are coming along great!
pvanweelden likes this.
ChuckTheRipper is offline
post #33 of 122 Old 11-24-2016, 07:48 AM Thread Starter
^ thank you! Hope your leg is healing up ok
post #34 of 122 Old 11-25-2016, 10:47 PM Thread Starter
Made a new top cap tonight
post #35 of 122 Old 12-02-2016, 10:41 PM Thread Starter
Haven't had much time this week, but still managed to find out my original design on my latches/pull wouldn't work, but fixed that and ordered a new set of interior handles.
Been experimenting with the Latch placement and have it finally dialed in, hopefully
Thankfully I made a few extras in different lengths, etc to experiment with.
Ordered and received the factory retainer clips for the uppers so I can make the steel bodies needed to actually mount them into the doors. Then I can test the height.
So, not much major progress, but still positive progress.
Here's a pile of shit.
Dirtman, if you are reading, I have a set of rubi 44's that I will trade if you pay shipping
post #36 of 122 Old 12-04-2016, 06:36 PM Thread Starter
Made a housing for the factory upper retainer clip. 7 more to go. Started with 2 plates and bent them. Their odd sizes doesn't play well with stock rectangular steel
post #37 of 122 Old 12-07-2016, 05:54 PM Thread Starter
Made a housing for the angled factory upper retainer clip. And made some more plates to make the rest of the housings.
post #38 of 122 Old 12-10-2016, 11:15 PM Thread Starter
Taking a little break from the doors to start a new project... making these brackets
That go here...
Any guesses on wtf I am doing?
post #39 of 122 Old 12-17-2016, 11:51 PM Thread Starter
No guesses? does this help?
post #40 of 122 Old 12-18-2016, 07:12 AM
4wheels4life's Avatar
I was going to say mounts for your front sway bar when it is disconnected. But the broke parts got me, no idea.
2007 JKU X, 6.0 ls and 6L80e with a diy kit from RpmExtreme, 4.10, 4" ProComp Stage 1 lift, AEV drop brackets, 325/65R18 Nitto Terra Grapplers, Eagle Offroad Alloys 18"x10"
4wheels4life is offline
post #41 of 122 Old 12-18-2016, 08:58 AM Thread Starter
Making a snow plow.
post #42 of 122 Old 12-18-2016, 10:03 AM
I was going to say it looked like a snow plow.
No I wasn't. I had no clue.
Apt and pvanweelden like this.
Kevin
gt1guy is offline
post #43 of 122 Old 12-18-2016, 04:25 PM
Is steel like really cheap where you live or something..
post #44 of 122 Old 12-18-2016, 05:06 PM Thread Starter
Lol, only if you buy it a sheet or a stick at a time. A local shop will cut me 8' or smaller pieces at similar prices as buying a stick. Most of the steel for the plow I had, about $120 if I had to buy it
post #45 of 122 Old 12-19-2016, 04:01 AM
bigworm36's Avatar
Aww that will be pretty sweet ! I forgot about snow plows ever since I moved from Ohio to Arizona!lol
Sent from my SM-N920T using Tapatalk
bigworm36 is offline
post #46 of 122 Old 12-23-2016, 06:11 PM Thread Starter
I probably should have started a separate thread on the plow, but tonight i got almost all the pieces cut out, just need to drill a bunch of holes and start welding. I will probably get a little work on the doors done next week.
post #47 of 122 Old 01-06-2017, 11:22 PM Thread Starter
Still not related to this thread, but made some progress on the snowplow
post #48 of 122 Old 01-07-2017, 11:15 PM Thread Starter
The mount minus the kickbacks to the frame mounts I made earlier
The push bar (upside down) and the mount
post #49 of 122 Old 01-07-2017, 11:57 PM
Related or not, that's damn slick.
Kevin
gt1guy is offline
post #50 of 122 Old 01-08-2017, 04:34 PM Thread Starter
^ thanks gt1guy. Started building the framework for the blade.
