40" Tires who's got'em - JKowners.com : Jeep Wrangler JK Forum
 14Likes
post #1 of 1116 Old 05-13-2010, 06:20 AM Thread Starter
fourplyn's Avatar
If you have 40" and bigger tires...Lets see pics..
But please include Info..( Size tire, size wheels, offset, spacer's or not)
Past jeep:
- 40" Pro Comp X-Terrain
fourplyn is offline
post #2 of 1116 Old 05-14-2010, 10:47 AM
Slow and Low
Co4Lo's Avatar
Bump.
Co4Lo is offline
post #3 of 1116 Old 05-14-2010, 11:00 AM
TrailDuty.com
PhilD's Avatar
Originally Posted by Co4Lo View Post
Bump.
Where's your pics?
PhilD is offline
post #4 of 1116 Old 05-14-2010, 11:06 AM
TrailDuty.com
PhilD's Avatar
Goodyear MT/R Kevlar 40x13.50x17
Allied Raceline Monster RT233 17x10.5x4
Alfie831 likes this.
PhilD is offline
post #5 of 1116 Old 05-14-2010, 11:48 AM
Slow and Low
Co4Lo's Avatar
Originally Posted by PhilD View Post
Where's your pics?
Well my YJ picture obviously killed the thread yesterday, So I wanted a fresh start.
Co4Lo is offline
post #6 of 1116 Old 05-14-2010, 11:52 AM
v10kingsnake's Avatar
Damn, 40's on a 4 door are looking so sweet these days... hmmmmmmm
2009 Sahara Unlimited. 5.7L Hemi truck setup. Rock Krawler 5.5 coil over LA. Maxxis Trepador 40's . ATX Rims, XRC front rear and side armor. RROR Crusher corners, RROR flat flares. Warn XD9000i. Prorock 44 with RCV shafts. 5.13 gears, ARB front and rear lockers.
v10kingsnake is offline
post #7 of 1116 Old 05-14-2010, 12:02 PM
Mr.RonGilbert's Avatar
Did someone say fawty!
Mr.RonGilbert is offline
post #8 of 1116 Old 05-14-2010, 05:22 PM Thread Starter
fourplyn's Avatar
Ok, anykind of 40...but make it BIG!
Past jeep:
fourplyn is offline
post #9 of 1116 Old 05-14-2010, 05:33 PM
TOTL Innovations
ALASHA's Avatar
I am way past 40s.
I have a 42....inch waist. You sure you want a pic of that?
ALASHA is offline
post #10 of 1116 Old 05-14-2010, 05:56 PM Thread Starter
fourplyn's Avatar
lol......ummm no...but 40" bust on a woman would be nice...
Past jeep:
fourplyn is offline
post #11 of 1116 Old 05-14-2010, 06:18 PM
Slow and Low
Co4Lo's Avatar
O.k. fine! I'm not gonna leave Phil out to dry on this one! Cheers Mate!
Co4Lo is offline
post #12 of 1116 Old 05-14-2010, 07:09 PM
TrailDuty.com
PhilD's Avatar
That's better, that's got to be one of the coolest looking JK's around
PhilD is offline
post #13 of 1116 Old 05-14-2010, 10:06 PM
JPTwinz's Avatar
Started life with 40x15.50R20 Nitto Muid Grapplers...
Them moved to 41x14.50R20 Iroks...
09 Unlimited Rubicon Flame Red
~8.5" TeraFlex LCG Long Arm
~41x14.50 Interco IROK Radials
~20x10 RBP-93R wheels with red inserts
~RCV Performance front D44 CV-style axle shafts
~Posion Spyder Crusher flares, Rock Brawler Bumper, Rocker Knockers w/sliders and Hawse fairlead
~Warn 9.5ti Winch w/synthetic line
~Rhino Lining tub
~Katzkin interior
~10lb Powertank & VIAR Xtreme
~Drake Off-Road billet bling
Check out my build here....
JPTwinz is offline
post #14 of 1116 Old 05-17-2010, 05:34 PM
38.5x13.50 17 Truxxus MT's on a 17x9 wheel
UnderPSI is offline
post #15 of 1116 Old 05-19-2010, 04:29 PM
str8country's Avatar
40" procomps on a 5.5" rockkrawler triple threat lift. 1.25" spacers
str8country is offline
post #16 of 1116 Old 05-19-2010, 04:47 PM
BLK RUBI ON 40s's Avatar
40x15.50 mud grapplers w/ 6" Teraflex LA kit, plus 1.25" wheel spacers:
Big Thanks to Jason at
Chromoly TR Beadlocks,
Katskins, and more!
BLK RUBI ON 40s is offline
post #17 of 1116 Old 05-19-2010, 05:12 PM Thread Starter
fourplyn's Avatar
Hey str8country...nice name...
Hey, can you post some shots of your rig on those tires sittin on flat ground...?
Past jeep:
fourplyn is offline
post #18 of 1116 Old 05-19-2010, 05:14 PM
Slippery's Avatar
Also running the 40" MTR Kevlars, the tallest 40 I've found.
Walker Evans beadlocks on a Rock Krawler 5.5" lift.
At Jeep Beach:
Wheeling:
Slippery is offline
post #19 of 1116 Old 05-19-2010, 10:56 PM
planman's Avatar
Still working on it.
Rear bumper isn't finished.
0.75" longer than stock rear lower arms seems to be about right.
Figuring out the needed extended bumpstops.
Looks like with my 3" OME and 1" BL, I need 2.5"-3" extended stops front and rear.
This is with 2.5" in the rear not entirely compressed and 2" in the front compressed enough that I went straight home and upped it to 2.5".
planman is offline
post #20 of 1116 Old 05-20-2010, 04:29 AM
TrailDuty.com
PhilD's Avatar
Before you decide on the front, turn the wheels from lock to lock when flexed out hard.
Looks good
PhilD is offline
post #21 of 1116 Old 05-20-2010, 05:30 AM Thread Starter
fourplyn's Avatar
Planman...lookin sick!
Looks like your almost there.. YOu still got some room left in the rear.. Might have to trim just a tad on the rear inner fender pinch seam on the back of the tire.
Are you still running rear sway bar's? The fronts aren't hooked up obviously..lol
That might be all you can get if the rear's are still installed.
Front looks nice, but I'm sure once you run it through its paces completely..you'll have it dialed in..
Past jeep:
fourplyn is offline
post #22 of 1116 Old 05-20-2010, 07:34 AM
planman's Avatar
Looks good
Yeah, I found out I needed to do some trimming at the front edge of the front fender well.
Also, it popped out the lower front plastic grill a little. I either need to consider running wheel spacers, or trimming the front plastic grill similar to Co4Lo, or a combination.
With 4.5" wheel backspacing, I had to adjust my steering stops significantly. Teraflex makes a 1.25" wheel spacer that would put me at 3.25" net backspacing.
New steering stops:
Thanks. Still have the rear swaybars on. I'll install front links when I figure out a good length.
planman is offline
post #23 of 1116 Old 05-20-2010, 07:45 AM
Prope's Avatar
This is close to level, he may have a better one. It's huge in person!
'08 Unlimited Sahara - Hemi -
Fenders & Rockers -
Prope is offline
post #24 of 1116 Old 05-20-2010, 08:37 AM
BenFoo's Avatar
ToyoMTs 38x14.5R16 (new Toyo size 385/70R16) on Stockton Series-22 16x10 3.5"B/S
BenFoo is offline
post #25 of 1116 Old 05-20-2010, 08:41 AM
BenFoo's Avatar
oops....missed this one.
BenFoo is offline
