Winch drum not aligned with fairlead - Superwinch - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 08-19-2009, 06:56 AM Thread Starter
BADGER's Avatar
Quick question for you guys. I finally got around to pulling my old POS winch from my bumper, and dropped in my Superwinch EPi 9.0 (you know, the notoriously killer winches that are also notoriously difficult to fit). It dropped in with room to spare, but the fairlead and drum do not completely align. The drum ends up sitting about 1/2" - 3/4" inch to the right of center with the fairlead. I'm using Viking synthetic line and a Hawse fairlead.
Is this okay, or do I need to perform some bumper surgery to get the two in alignment?
BADGER is offline
post #2 of 10 Old 08-19-2009, 01:42 PM
Fistfull of Boomstick
usmcdoc14's Avatar
should be fine, you can always re-drill the holes. Are the mounting holes centered to the opening?
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline
post #3 of 10 Old 08-19-2009, 02:16 PM Thread Starter
BADGER's Avatar
Let's see if I can explain this....
There are two sets of mounting holes in the bumper (this is a Hard Rock bumper with a recessed mount). They are not offset much from each other. Using the holes that would mount the Superwinch without modifying the bumper, that's when I get the drum/fairlead offset. The brake-end of the winch housing contacts part of the bumper plate in this scenario but fits.
I can't use the other set of holes because the brake-end of the winch housing is stopped by the edge of the bumper plate before holes can align. If I trim the edge of the bumper plate a bit, I can reach the holes and the drum/fairlead should align almost perfectly. But, it's 1/4 plate and it's a pretty stout job to cut or grind it down.
Does that make sense?
BADGER is offline
post #4 of 10 Old 08-19-2009, 06:20 PM
usmcdoc14's Avatar
I would grab the 4.5" grinder and a flap wheel and make some clearance, but thats me
post #5 of 10 Old 08-20-2009, 06:49 AM Thread Starter
BADGER's Avatar
That's pretty much what I'm leaning towards myself....
BADGER is offline
post #6 of 10 Old 08-20-2009, 11:30 AM
JKDoc's Avatar
My Shrockworks bumper came with the opening offset, I assumed to line up with the winch they were selling. My Mile Marker hydraulic lined up with the center of the bumper. This had the fairlead and drum about an inch off centering with the opening. Everyone said it would be ok but I've read that with the synthetic line you want as little tight bending of the line as possible and certainly you don't want to pull the line across a sharp edge of the bumper cut out. We extended the opening, made a new backing plate with opening centered for the winch drum and mounted the fairlead to the backing plate, the backing plate to the bumper. It looks like it was designed that way and the line makes no contact with any part of the bumper.
JKDoc is offline
post #7 of 10 Old 08-20-2009, 12:26 PM
jdrogers's Avatar
This is what I basically did for my SuperWinch on the Mopar rock bumper that hase the fair lead off center to fit a Warn winch. But on mine I welded a new plate to the bumper to center the fair lead.
2007 Stone White Rubicon
jdrogers is offline
post #8 of 10 Old 08-20-2009, 01:54 PM Thread Starter
BADGER's Avatar
I'll have to take a second look and see just how far off it is. If the line might touch something other than the fairlead, then I'm gonna have to get to work. If it doesn't I'll just leave it.
Because of the way the bumper is designed with the current mounting hole and fairlead configuration, it will definitely make more sense and be easier to grind away part of the top bumper plate to accommodate the winch end rather than mess with the fairlead slot/mount.
BADGER is offline
post #9 of 10 Old 08-24-2009, 07:32 AM
JKDoc's Avatar
We were able to open the slot easily. The problem then came trying to mount the fairlead. That was why we needed to add the extra plate.
JDROGERS, that really looks good. I did not want to repaint the bumper so mine is bolted.
JKDoc is offline
post #10 of 10 Old 08-24-2009, 07:37 AM
JKDoc's Avatar
That really looks good. I did not want to repaint the bumper so we bolted the plate in.
[IMG][/IMG]
JKDoc is offline
