POLY PERFORMANCE JK LONG ARM KIT SPY PICS-------------------------------------------> - JKowners.com : Jeep Wrangler JK Forum
post #1 of 93 Old 02-09-2009, 05:46 PM Thread Starter
PIG
PIG's Avatar
Well here you go..... The 2 door just came back from a weekend of testing at Johnson Valley............
PIG is offline
post #2 of 93 Old 02-09-2009, 05:47 PM Thread Starter
PIG
PIG's Avatar
More
PIG is offline
post #3 of 93 Old 02-09-2009, 05:49 PM Thread Starter
PIG
PIG's Avatar
Running for 2.5 reservoir shock all the way around with the prototype 2.0" FOX air bumps in the front...
PIG is offline
post #4 of 93 Old 02-09-2009, 05:49 PM
um....
When, how much? And action pics please.....
a-squared is offline
post #5 of 93 Old 02-09-2009, 06:13 PM
Interesting sideways mount for the upper arm(s).....
post #6 of 93 Old 02-09-2009, 06:22 PM
RotorHead's Avatar
Yeah, how's that work?
RotorHead is offline
post #7 of 93 Old 02-09-2009, 06:38 PM
X3???
Further away pics???
Action pics???
505JK is offline
post #8 of 93 Old 02-09-2009, 06:57 PM
Administrator
HITMONEY's Avatar
X4.. with a normal looking bushing?? How does that articulate?
Inquiring minds want to know!
°lllll°
Facebook Page
YouTube Channel
HITMONEY is offline
post #9 of 93 Old 02-09-2009, 07:08 PM
Matt's Avatar
It articulates fine mounted like that because there isn't much movement there.
My guess is its some sort of cartridge joint judging by the grease zerk.
Matt is offline
post #10 of 93 Old 02-09-2009, 07:57 PM Thread Starter
PIG
PIG's Avatar
Yes....
PIG is offline
post #11 of 93 Old 02-09-2009, 09:09 PM
Is the rear end a trilink or is that a narrow mount for the upper arms?
LoPo is offline
post #12 of 93 Old 02-09-2009, 10:17 PM Thread Starter
PIG
PIG's Avatar
Yes, single upper link...
PIG is offline
post #13 of 93 Old 02-09-2009, 10:22 PM
What's Poly's thought behind that? Isn't Rock Krawler the only other co. doing this? Does it provide an advantage over a 4 link?
LoPo is offline
post #14 of 93 Old 02-10-2009, 06:28 AM
I think the advantage in relation to the JK is avoiding the gas tank but I'd like to hear if there is any performance gains.
505JK is offline
post #15 of 93 Old 02-10-2009, 09:52 AM
Bump for my boner.....
post #16 of 93 Old 02-10-2009, 10:19 AM
The front upper link joints are vertical like that to squeeze it between the cat/exhaust and the frame, you can fit a joint flat there but you cannot get the bolt in or out. We are using a Johnny joint there, it has plenty of angle for that application.
There is a single rear upper link, mostly for packaging, there is no room outside of the frame to make the rear upper arms much longer, they are too short IMO if you put them outside the frame like others do. Performance wise there is no real difference, a 3 link+track bar can work better than a 4 or 5 link if the geometry is right. A link suspension system needs a total of 4 links to constrain it, 3 + track bar or 4 with 2 of them triangulated. The stock jeep is a 5 link and is overconstrained so the bushings and arms have to deflect a lot to keep it from binding. A 3 link +track bar will articulate a little easier.
Here is a shot of the upper link mount
Last is a shot at the top of Jackhammer
GOAT1 is offline
post #17 of 93 Old 02-10-2009, 10:39 AM
Any action pics that show it flexing better than what my budget boost can already do?
stroke it a little....give me the good stuff...
post #18 of 93 Old 02-10-2009, 10:45 AM
The flex all depends on the length of the shocks, this kit used the same shocks as our other kits. Difference is ride, handling and performance of the better link geometry.
GOAT1 is offline
post #19 of 93 Old 02-10-2009, 10:55 AM
k, Cool. Thanks. Keep going with this...the potential is pretty impressive.
post #20 of 93 Old 02-10-2009, 02:58 PM
If you can fit a joint in there in the flat position, why not drill a hole through the frame and insert the bolt from the outer side of the frame and have the nut on the side of the cat/exhaust? You could even sleeve the hole through the frame if you wanted.
505JK is offline
post #21 of 93 Old 02-10-2009, 03:09 PM
Yeah you could but it works just fine this way, drilling holes in the frame is a PITA, there are no other holes to drill for the rest of the kit.
GOAT1 is offline
post #22 of 93 Old 02-10-2009, 03:12 PM
Any plans for a four door kit? Or a brackets and arms only kit?
post #23 of 93 Old 02-10-2009, 03:15 PM
It should be all the same parts, works for both. We just did it on the 2 dr first because we are racing it in the King of the Hammers race in 2 weeks.
GOAT1 is offline
post #24 of 93 Old 02-10-2009, 03:22 PM
what class is your rig going to race in?
post #25 of 93 Old 02-10-2009, 03:39 PM
There are not classes for KOH, its all pretty much unlimited. We will start a new thread for that soon, but we are running our 2 dr JK with only all available aftermarket parts. Mostly our stuff with Currie rock jocks and 39" Krawlers.
GOAT1 is offline
