Mopar Dana 60 - JKowners.com : Jeep Wrangler JK Forum
post #1 of 24 Old 09-27-2008, 08:43 AM Thread Starter
Mopar Dana 60
Thought I would fill you guys in....
http://www.quadratec.com/products/52446_103_T.htm
NickH is offline
post #2 of 24 Old 09-27-2008, 08:47 AM
Nice...now maybe the 44s will drop even lower.
karnuvore is offline
post #3 of 24 Old 09-27-2008, 08:50 AM Thread Starter
For a rear 44, maybe...
Your still subject to excessive anal fornication on the front!
NickH is offline
post #4 of 24 Old 09-27-2008, 09:09 AM
I think the price now isnt bad. But Im always optimistic about it going even lower!
post #5 of 24 Old 09-27-2008, 09:17 AM Thread Starter
Add the price of new axles and gears and to me it's a waste.
NickH is offline
post #6 of 24 Old 09-27-2008, 09:26 AM
Openly Hostile
For a couple hundred more you can buy a Currie rock jock 60 with whatever gears and locker you want. The base price is $1900, with 5.40's and an ARB the price come in right at $3000 if I recall correctly.
Jason
SDMF is offline
post #7 of 24 Old 09-27-2008, 09:49 AM
Their picture is of a D44. The Mopar part # P5155083 is for the Jeep J8 model. So no locker, 5x5.5 lug pattern and brackets for leaf springs.
n8it is offline
post #8 of 24 Old 09-29-2008, 09:13 AM
Administrator
HITMONEY's Avatar
Thats the information I have as well... the 60 comes set up for leafs and supposedly the brackets are $400.00 to convert, but I don't have any concrete proof of that.
The problem with the Rock Jock is that that I want plug and play e-lockers and that isn't possible with the Rock Jock.
Even with a 60 in the back you are still limited to 5.13's if you run a 44 in the front and with a 60 I want to go 40's with 5.38. So considering all that it would have to end up being Rock Jocks front and rear with ARB lockers and no more e-locker.
Probably looking between 6 and 7k by the time it is all said and done, then subtract about $2000 from selling my 44's and its a 5k swap if ya do it yourself and that is before the cost of 40" tires.
This is still a little off in the distance for me...... but not to far.
HITMONEY is offline
post #9 of 24 Old 09-29-2008, 09:19 AM
Openly Hostile
Just curious why you would want an e-locker instead of an ARB? seriously?
As for the gears, Alloy is supposed to have their 5.38 d44 gears out one of these months, so that gives you options. I have been waiting for these myself.
Jason
SDMF is offline
post #10 of 24 Old 09-29-2008, 10:05 AM
Administrator
HITMONEY's Avatar
Originally Posted by suthernjeeper View Post
do you plan on changing your lift any?
Maybe... not sure yet. Pretty sure I will ad a BL to the suspension lift and maybe.. just maybe a coilover system.
I like the E-lockers. In my mind, correct me if i am wrong or way off base, electric is far more reliable than Air and probably runs a close second behind manual/OX in terms of reliability.
I have heard and seen far to many stories of air pumps going bad and air leaks. My friend has a top quality built TJ with ARB and it seems he is always working on the ARB air system. No thanks.
As far as 5.38's in a 44... that is pushing it.. not sure how strong that is gonna be... but yeah I've heard the rumor of them for quite some time now.
HITMONEY is offline
post #11 of 24 Old 09-29-2008, 10:25 AM
Openly Hostile
Maybe I am just unlucky, cause I have had my elockers not want to unlock several times.
Jason
SDMF is offline
post #12 of 24 Old 09-29-2008, 10:33 AM
Administrator
HITMONEY's Avatar
I have had sway bar issues, but no locker issues. And even then, the sway bar problem was just because they weren't aligned properly.. wasn't an electric problem or motor problem.
I am constantly engaging and disengaging my e-lockers on the trail with no issues..... yet.
I know alot of people that were having e-locker issues was caused by improper assembly when doing a re-gear and the solenoid was getting damaged... and then the whole ARB Diff cover debacle that I never found out if in fact the ARB cover was interfering.
HITMONEY is offline
post #13 of 24 Old 09-29-2008, 10:51 AM
Openly Hostile
Come to think of it, I have not had an issue with my locker since I put the ARB covers on it...had solids on before that. It was always the front one.
Jason
SDMF is offline
post #14 of 24 Old 09-29-2008, 06:56 PM
md_rubi's Avatar
If you are having e-locker issues, it's because of the fluids you used(so this is what i was told by service guys). I had problems with my e-lockers ever since i had to change the dif cover and even though I used high quality fluids, e-lockers (service guys told me) requires special fluids. my dealer replaced the lockers under warrenty but told me they could have charged me since i did not use recommend fluids.
As for Air lockers, i have had issues with either the air compressor and/or the hose.
OX, i'm understanding is having issues with development and they currently do not have a way to test their system on JKs. Detroit is the only one i am considering at this time for my d60 swap. i hear it is not fun to drive on pavement.
md_rubi is offline
post #15 of 24 Old 09-29-2008, 07:02 PM
Openly Hostile
What were you using in it? I have been running royal purple since I changed it the first time.
Jason
SDMF is offline
post #16 of 24 Old 09-30-2008, 08:02 AM
Administrator
HITMONEY's Avatar
If you don't have MOPAR fluid in it, it gives them an "out" to tell you thats what it is.
Royal Purple in mine as well.. no locker issues.
HITMONEY is offline
post #17 of 24 Old 09-30-2008, 10:37 AM
mrsig's Avatar
I have had no problems with the lockers at all and I run regular gear oil. I am now @ 17,000 miles.
CEO of Black Sheep 4x4s
mrsig is offline
post #18 of 24 Old 09-30-2008, 03:02 PM
md_rubi's Avatar
I use Royal Purple. Have you guys looked at eaton's e-locker?
md_rubi is offline
post #19 of 24 Old 10-01-2008, 07:55 AM
bobtail82's Avatar
got the 60 in front of me. it is leaf spring setup ,but it does have a locker,possable detroit. need to open it up and make sure
tony
bobtail82 is offline
post #20 of 24 Old 10-01-2008, 08:46 AM
tony
I thought they had Trac-Lok limited-slip in them, but not an electric locker to plug into a JK's wiring harness.
n8it is offline
post #21 of 24 Old 10-01-2008, 09:10 AM
FL JEEPN's Avatar
As long as the fluid you use meets MOPAR requirements their "out" goes right out the door!
I don't have lockers...prolly will one of these days, but I do have Amsoil fluid sitting on the shelf waiting for me to have time to change both diffs.
07 JK Unlimited X - 24s, Soft, Auto, 4:10's, Saraha 18's. OME Springs and Shocks, JKS Front and Rear Adj. Bars, JKS Disco's, Spidertrax Wheel Spacers, Mopar Trail Guide.
01 WJ Limited -- Gone to make room for JK Unlimited!
01 TJ for me and my son-----BYE BYE TJ see you on the trails someday....
.__0_0_0_0
[l_,[____],
l---L -OlllllllO-
()_) ()_)---)_)
FL JEEPN is offline
post #22 of 24 Old 11-02-2008, 06:45 PM
RODICON's Avatar
Too bad you can't get it with factory elect. locker.
RODICON is offline
post #23 of 24 Old 11-12-2008, 09:41 PM
A problem with the gear lube was synthetic in an older Rubicon with the air actuated locker. The internal air line was a funky ruber that swelled up and sliped of the nipple when synthetic was used.
Stumpalump is offline
post #24 of 24 Old 03-11-2009, 11:25 AM
Trail Concepts Hmfic
jdemonto's Avatar
The J8 D60 does have a trac-loc limited slip. I run an Eaton E-locker in my TJ D44 and have 15K trouble free miles, I may get one for the rear in the near future. Also the J8 front D44 has stronger axle tubes.
Jason
602-314-5356 or
jdemonto is offline
