TeraFlex: New Falcon Shocks! - JKowners.com : Jeep Wrangler JK Forum
 3Likes
  • 1 Post By TeraFlex
  • 2 Post By wellstig1
post #1 of 15 Old 10-31-2016, 11:23 AM Thread Starter
TeraFlex's Avatar
More information here: https://teraflex.com/shop/category?u...9C%93&q=Falcon
Description
The Falcon Series 3.3 Adjustable Piggyback Shock is designed and engineered to deliver race inspired performance and handling while exclusively built to the specific requirements of the Jeep Wrangler. Vehicle stability is the paramount goal with all Falcon shocks.
For years shocks have been simply ‘adapted’ with minimal tuning and not specifically designed for an application. Falcon Shocks changes that mentality. The Falcon Series 3 Piggyback shocks are corner specific, built from the ground up, and deliver the best damping characteristics possible with fitment and function outlining the highest priorities. A lengthy and painstaking development process has finally delivered these new advancements to a waiting Jeep market.
The front shock features a unique piggyback design with the reservoir positioned horizontally to increase clearance with large tires during articulation and turning. An offset upper stud positions the shock body away from the frame for maximum clearance.
The rear shock positions the body and reservoir at the bottom to eliminate shaft damage from rocks kicked up by the tires. The outboard mounting increases clearance for lifted vehicles with raised track bar brackets.
Falcon shocks feature Lucas Oil full synthetic shock oil for superior performance across all temperatures to reduce shock fade. The proprietary synthetic formula also contains special anti-wear and lubricity agents that produce excellent thermal stability.
Falcon Series 3.3 adjustable piggyback shocks are available in different performance levels including adjutstable and non adjustable versions.
Features & Benefits
- JK specific shock
- Increases vehicle stability
- Improved dynamic roll control
- Improved low speed damping
- Optimized fitment for clearance during full suspension travel & articulation
- Front offset stud design creates additional frame clearance
- 2.25” shock body provides optimal performance
- Largest shock body that will fit without modifications
- 6061 aluminum hard anodized shock tube resists wear
- Smooth honed internal shock body surface for long term performance
- ” shaft to prevent shaft buckling
- Maximum shaft diameter for optimal adjustable range
- Hard chrome, induction hardened shaft resists rock damage and corrosion
- OGS – the oil/gas separator prevents cavitation
- Digressive linear piston & base valve technology
- One-piece Teflon bronze piston wear band with o-ring
- Fast Adjust Knob (Series 3.3) for quick compression adjustments
- Compression cartridge system can be added to Series 3.1 piggyback shocks by owner after purchase
- Piggyback design increases fluid flow by 6x over restricting reservoir hose designs
- Piggyback fluid passage eliminates common leakage issues found in banjo & swivel fittings
- Hard anodized billet piston
- Aluminum construction for superior heat dissipation
- Lucas Oil full synthetic shock oil
- 1,000 hour salt spray corrosion resistance on all hardware
- Serviceable & rebuildable (factory serviced)
- Upgradeable in stages
- Built in-house in the TeraFlex Falcon shock division
- Fits all JK Wrangler models including Rubicon and Unlimited
- 3 year warranty
- Patent pending design
Rubi-8 likes this.
1-888-837-2359
TeraFlex never left the market or the trail.
TeraFlex is offline
post #2 of 15 Old 10-31-2016, 08:57 PM
Looks interesting
Pyroladine is offline
post #3 of 15 Old 11-02-2016, 10:29 AM
That rear design is terrible, anybody who plays in the rocks will destroy that piggyback reservoir. I think they should go back to the drawing board to get the rears flipped the other way.
kjeeper10 and PED'sReady0219 like this.
wellstig1 is offline
post #4 of 15 Old 11-02-2016, 01:15 PM
kjeeper10's Avatar
I mentioned that on FB. Awesome looking shocks none the less.
2007 JKR | Rock Krawler 3.5" x-factor l SteerSmarts YETI tie rod and flipped drag link | Synergy frame brace | Superlift front track bar l 37x12.5x17 MTR's on MB72's | Adams front DS | Rancho 5000x shocks | Artec front armor kit/Currie JJ's | Teraflex rear axle bracket | RK rear track bar | EVO Rockstars | Ridged D's, A pillar mounts | Fox ATS | VKS sliders l Superchips/Sprint booster | Savvy half doors |
kjeeper10 is offline
post #5 of 15 Old 11-02-2016, 01:36 PM
1eviljk's Avatar
The video shows them being dragged over rocks and they held up fairly well but what would they look like 6 months later after multiple wheeling trips.
1eviljk is offline
post #6 of 15 Old 11-02-2016, 01:41 PM
Rubi-8's Avatar
I had the same thought. There is a big difference between dragging a $130 shock vs dragging a $350+ (guessing) shock.
Rubi-8 is offline
post #7 of 15 Old 11-02-2016, 01:44 PM
I'm wondering how the travel on these compares to the shocks they currently sell with their lifts. As far as the rear piggybacks, I can see me smashing those beyond repair fairly quickly. Guess it's a good thing they have a 3 year warranty.
PED'sReady0219 is offline
post #8 of 15 Old 11-03-2016, 09:19 AM
kjeeper10's Avatar
I just watched the other 2 videos. Damn these are nice shocks.
The shaft is freaking HUGE.
post #9 of 15 Old 11-03-2016, 09:30 AM
only 3/4" shafts. king uses 7/8" on their performance shocks.
New to jeeps, check this link
post #10 of 15 Old 11-03-2016, 10:48 AM
@TeraFlex when are these going to be available to purchase? And do you have the extended/compressed lengths available for the 2.5"-3" version?
post #11 of 15 Old 11-04-2016, 10:59 AM Thread Starter
TeraFlex's Avatar
All Falcons will be released Jan 2017!
Hey guys, great questions about the reservoir built on the bottom instead of the shaft. For one, these shocks are designed to take a hit. The bushing allows some swivel-movement so the body can deflect from larger obstacles without causing damage to the shock. We have also moved the shock outward from the centerline of the jeep towards the tire for more protection and it fits perfectly with jeeps with a raised rear trackbar bracket, where most shocks rub and hit, causing significant damage.
Another major benefit and reason we did the body downward is that the shaft can be easily damaged by rocks and debris kicked up by the front tires and as soon as there is a knick in the shaft or scratches, those pass the seals of the shock every time the shock compresses and extends and can very easily cause premature failure of the shock. Our shaft is tucked up close to the body and protected from these scenarios.
We went the extra mile to give our customers extra protection on the body by having the aluminum body "Type 3 Hard Anodized" which is incredibly hard for superior protection. The thickness of the body cap and the body is also extremely overkilled to take a beating and keep on going, where as if you take a hit to your shaft, you're done. Your shock will start leaking and you will have to send it in for repairs or buy new shocks.
Also, one of our big things is fitting with OEM applications with none to very minimal modification of components to fit, where as some of the bigger shocks with 2.5" bodies require significant modification such as removing or relocating the rear swaybar, aftermarket exhaust, trimming of the factory shock bracket, etc. These are basically a bolt in and go solution with superior performance, will fit from mild to wild builds, and the easiest adjustment that you will actually use (without burning your arm on the exhaust or pulling out a mirror to look up under the jeep to see what setting your adjuster is on). 30 seconds and you can have all your shocks adjusted from street driving and ready to hit the trails. No other shock on the market for the JK offers that. Hope that helps!
For those with great concern, we will be offering a bolt on skid plate that contours the body cap and extends to provide extra protection for the adjusters and will help further protect your investment. Look for more info coming in the next few months.
1-888-837-2359
TeraFlex is offline
post #12 of 15 Old 01-25-2017, 08:02 AM
Anything on these shocks yet? Have they started shipping? Any reviews?
Mr. Incredible is offline
post #13 of 15 Old 01-25-2017, 08:39 AM
kjeeper10's Avatar
Only the Stabilizer from what i see.
post #14 of 15 Old 02-23-2017, 03:32 PM
kjeeper10's Avatar
Well that answers that question
https://www.facebook.com/FalconShock...9349755835034/
post #15 of 15 Old 02-28-2017, 08:29 PM
b1pig's Avatar
some of the pricing doesn't look that bad. Pretty competitive with others on the same level. I'll probably be buying the steering stabilizer soon. I need new shocks too, but I can't have everything.
'15 Ram 1500, '15 Challenger SXT
2008 Kawasaki KLR650
b1pig is offline
