6.1 Hemi conversion question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 04-12-2010, 02:32 PM Thread Starter
jrc
does anyone know if a 2006 Dodge Charger 6.1 Hemi motor will fit in a JK?
jrc is offline
post #2 of 5 Old 04-12-2010, 02:38 PM
TOTL Innovations
ALASHA's Avatar
All Hemi engines will technically "Fit" in the JK. The issue is with how the front accessory system is set up. Check with the company whose kit you want to use to see if the kit works with that engine. The AEV for example recommends Hemis out of Cherokees and Commanders and JSS uses hemis from Rams.
ALASHA is offline
post #3 of 5 Old 04-12-2010, 03:38 PM
txjeeplover's Avatar
I've been doing research on this topic and yes the 6.1 from the Charger will work but you'll have to change the oil pan and pick up. There are 2 variations of the accessory drives for the 5.7 (LX and DR) but one setup for the 6.1.
2008 2 Door Rubicon
4" Zone Lift
15x10 Ion 138
35x13.50R15 Toyo Open Country MT
A bunch of other stuff done and yet to do
txjeeplover is offline
post #4 of 5 Old 04-12-2010, 05:42 PM
scrogg's Avatar
not knowing if your planning on keeping on the street or not, but doesn't the engine have to come out of the same year or newer for emission reasons?
scrogg is offline
post #5 of 5 Old 04-12-2010, 06:08 PM
That's a safe rule of thumb to meet 50 state engine swap requirements but rules actually vary state to state. For example, in Texas the only requirement is that the vehicle have all the emissions components that were present when the vehicle was manufactured.
2008 2 Door Rubicon
4" Zone Lift
15x10 Ion 138
