Does this trackbar bolt have too much play - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 04-01-2012, 10:57 AM Thread Starter
V8 dreams
jvandy50's Avatar
I'm trying to add the video from YouTube but can't figure it out...
Track bar mounting hole 99 XJ - YouTube
Vandy
2010 Silver JKU
jvandy50 is offline
post #2 of 8 Old 04-01-2012, 05:50 PM
planman's Avatar
Copy the URL and paste it in a reply, but omit he first letter. I'll see if I can make it work.
planman is offline
post #3 of 8 Old 04-01-2012, 05:59 PM Thread Starter
V8 dreams
jvandy50's Avatar
Is it not working now? I'm confused lol
Thanks planman
Vandy
2010 Silver JKU
jvandy50 is offline
post #4 of 8 Old 04-01-2012, 06:55 PM
planman's Avatar
Thanks planman
Vandy
It is working now.
Yes, that is way too much play. The most common approach is to weld plates and drill it out, or to weld washers there that would be snug on the bolt.
That would definitely be a source of DW.
planman is offline
post #5 of 8 Old 04-01-2012, 07:13 PM Thread Starter
V8 dreams
jvandy50's Avatar
It is working now.
Thanks again for the advice planman. Now off to find me a welder...and a replacement bolt, since that one snapped in half as I torqued it to 74ft/lbs
Vandy
2010 Silver JKU
jvandy50 is offline
post #6 of 8 Old 04-02-2012, 10:23 PM
planman's Avatar
Vandy
Double check the recommended torque spec. It might be as low as 55 ft lbs for the axle side bolt for a TJ/XJ.
planman is offline
post #7 of 8 Old 04-03-2012, 08:38 AM Thread Starter
V8 dreams
jvandy50's Avatar
I'm finding inconsistent numbers for factory torque specs posted across different forums. I've found 40 to 74. Obviously 74 was too much for the one I had. The most common number I'm finding is 60. I will ask the parts guy when I pick up my new bolt and flange nut. I think I found a welder today too!
Vandy
2010 Silver JKU
jvandy50 is offline
post #8 of 8 Old 05-04-2012, 07:29 AM Thread Starter
V8 dreams
jvandy50's Avatar
Had washers welded to trackbar holes. Didn't fix it. I messed up the steering stab trying to get it off and so I got to buy a new one. Dealership had to do it cause I couldn't ever get the fn thing off. Just went over a bridge and watdya know the wobble is just as bad if not worse. Bad morning
Vandy
2010 Silver JKU
jvandy50 is offline
