Welcome To JKOwners Forum
JKOwners Forums
JK Technical Sections
On the Trail
Discuss your favorite Trails and Events here!
JK Community
Marketplace
Vendor Member Section
Want to Grow Your Business? Learn more about becoming a Supporting or Premium Vendor
Forum Support
Off Topic Discussions
Regional Forums
Latest Posts
hello I have a jeep wrangler jk 2014 v6 I have the error code p258a however I dismantled the brake vacuum pump and it works on the battery I am looking for an electrical diagram where to find the relay thank you all0 replies 32 views
My 2015 Rubicon JKU 100k miles developed the rocker arm tick. I tore it down replaced all the rockers and lifters. I noticed scorching on my left exhaust camshaft so I ordered a camshaft off parts geek to replace it. When the camshaft came I noticed it didn't have the black metallic ring on the...1 reply 88 views
Hi All! Long time lurker, first time poster! I have a problem that i have not been able to find the answer to anywhere. I have my stability control light on and cant figure out what is wrong. It is showing code C1082, Vacuum pressure sensor circuit. I have changed the sensor attached to the...4 replies 7K views
What’s everyone’s thoughts on these tops? Any problems, leaks, not sealing good etc.?12 replies 10K views
has anyone purchased a dv8 hood for a jk and found it howels at certain speeds above 60 k ,40 miles per hr . drove it with the hood off ,noise is gone , put it back on , noise is back ? thanks , tried blocking all the vents ect nothing works !2 replies 119 views
