Winch under water - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 01-06-2009, 12:46 PM Thread Starter
bodybrdng's Avatar
Winch under water
If a winch gets submerged. What should be done?
bodybrdng is offline
post #2 of 13 Old 01-06-2009, 12:50 PM
mcnaught6's Avatar
drive out of the water, at some point.
mcnaught6 is offline
post #3 of 13 Old 01-06-2009, 12:53 PM
LOL^^
What winch do you have and how long was it submerged?
WTF_LOL is offline
post #4 of 13 Old 01-06-2009, 12:57 PM Thread Starter
bodybrdng's Avatar
lol
Just a general question
I meant once you get home.
It hasn't happened yet. I know it will happen one day. This way I will already have an idea.
I assume you disassemble the winch, clean and dry everything, regrease, and reassemble.
post #5 of 13 Old 01-06-2009, 01:00 PM
If it was not submerged long and is a good maker then it should be fine. Most winches are pretty well sealed. YOu be the judge...if you think there is reason to belive much water got inside you could buy a tub of grease and break the winch down and re grease it but I think that would be overkill if you just drove through a puddle with a WArn or something
EDIT: Missed the second part of your post saying it has not happened yet, lol
WTF_LOL is offline
post #6 of 13 Old 01-06-2009, 01:03 PM Thread Starter
bodybrdng's Avatar
I ordered a smittybilt xrc-10. From what I understand that are T-max whinches with smittys name on it.
post #7 of 13 Old 01-06-2009, 02:42 PM
my winch gets wet when I talk dirty to her. Do you really wanna know what I do next?
karnuvore is offline
post #8 of 13 Old 01-06-2009, 03:06 PM
beagsjeep's Avatar
Never had a issue with mine.i swamp the $hit out of mine works when i need it.i got stuck in this one water hole the winch was almost cover in water .pull wright out..thanks smittybilt
beagsjeep is offline
post #9 of 13 Old 01-06-2009, 05:47 PM
Obviously corrosion can be a problem. One of the problems a friend had was that a couple of years after being in a flash flood, his winch did not work. He had not used it many times over the intervening years (about three). The brushes had become corroded and the springs could no longer push into the armature. We had to take that side of the winch apart, clean and put back together. The winch did work for a while until the brushes no longer made contact. I was also in that flash flood, but I use my rig more than he does and I don't have a problem.
So, you could take the side cover off and blow water out.
2008 JK Rubicon
86ish Formula Toyota
OlMan is offline
post #10 of 13 Old 01-08-2009, 05:58 PM Thread Starter
bodybrdng's Avatar
So would you (others) say that it is a good idea to take it apart and clean / regrease every few months ?
Sorry if that sounds dumb. Just never had a winch before.
post #11 of 13 Old 01-08-2009, 06:39 PM
BeerMonkeY's Avatar
i had mine drowned several times over the last 10 years (had it on 3 other jeeps) i rebuilt it about 2 years ago and it was pretty nasty inside, i pulled the gears out and re-greased it all, i also had to replace the control plugin and 2 solinods
'92 YJ-8.8,d30,lunchbox locked,35's
'13 WK2-hemi,leveling lift.
BeerMonkeY is offline
post #12 of 13 Old 01-08-2009, 06:41 PM
BeerMonkeY's Avatar
oh its a warn M8000
post #13 of 13 Old 01-08-2009, 10:43 PM
Comfortably Numb
RubiCajun's Avatar
Fray your cable?
RubiCajun is offline
