winch switch inside Jeep for 9.5TI - JKowners.com : Jeep Wrangler JK Forum
post #1 of 29 Old 12-29-2008, 11:41 PM Thread Starter
vegasjeep's Avatar
ANyone ever do one?
08 Rubicon Unlimited-Just about stock!
I'll keep my guns, my freedom, and my money... You keep "The Change"!
Ask me about SH!TTY companies like Full Traction, Pure Jeep, and others!
vegasjeep is offline
post #2 of 29 Old 12-30-2008, 12:23 AM
I was gonna do a quick write up tomorrow when I could get a couple more pics but here ya go. Shows a different model but should be the same. Just locate the proper wires.
Based on information found on the internet and modified a little for how I did it. Works just fine for me.
WTF_LOL is offline
post #3 of 29 Old 12-30-2008, 12:41 AM
9.5ti solenoid
WTF_LOL is offline
post #4 of 29 Old 12-30-2008, 12:55 AM
BTW, when I was looking for a pic of the selonoid I found this thread. May be one you might wanna bookmark if thats the winch you have
http://www.greatlakes4x4.com/showthread.php?t=69556
WTF_LOL is offline
post #5 of 29 Old 12-30-2008, 11:45 AM
12voltguy.com's Avatar
Originally Posted by vegasjeep View Post
ANyone ever do one?
post just below yours
pic under my name
I also make small 2x2.5 starting at $35.99
http://12voltguy.com/web/index.php?p...mart&Itemid=43
started install of 12 volt guy panel
COVER of 4Wheeler mag DEC 2010...right now
530.532.4529
12voltguy.com is offline
post #6 of 29 Old 12-31-2008, 10:13 PM Thread Starter
vegasjeep's Avatar
thanks for the thread link. Bookmarked.....
I am going to do an in cab winch controller with some Aux switched. Hate getting out the remote every time I need ot winch.
post #7 of 29 Old 12-31-2008, 10:16 PM
Thats why I did it also. I still would get out and use the remote for some crazy extraction but for those little trail yanks on the rig in front of you it is nice to not have to do anything but hit a switch while they cary the line, lol
WTF_LOL is offline
post #8 of 29 Old 01-02-2009, 09:28 AM
John L's Avatar
That's cool Scott, nice job. I've been wanting to do the same thing but I'm having trouble finding a schematic for the Powerplant. It's got some funky eight pin remote I can't seem to crack with the ohm meter. I read somewhere that the Powerplant is really a 9.5TI with the air stuff on it, can anyone confirm this? If it is, you have just solved my problem Scott.
/jl
Healthy is merely the slowest possible rate at which one can die.
John L is offline
post #9 of 29 Old 01-02-2009, 09:33 AM
email me
I have it
530.532.4529
post #10 of 29 Old 01-02-2009, 09:50 AM
Sounds like 12 volt guy has the schematics but now I am curious as to why the remote has 8 pins???
Is there aditional controls on the remote other then winch in/out??
If you have it handy, what color are the wires in the remote? DO they all connect to solenoid terminals?
Sorry bout all the questions, lol. Just can't see why there would be more then five
WTF_LOL is offline
post #11 of 29 Old 01-02-2009, 10:09 AM
I have the factory schematic
shows only 6 wires
BLK- LOOKS LIKE GROUND, NOT THERE IS NO DSPEC ON SHEET
GRN-POWER IN
ORN-POWER OUT..............ALSO COMNPTRSSOR ON
BRN-LED, COULKD BE SAME AS 9.5 TI OVERHEAT LED? SHOWS 1K RESISTOR
IN LINE WITH BLK
WHT-OFF
THESE 2 ARE COMPRESSOR
ORN-ON
BLU-OFF
530.532.4529
post #12 of 29 Old 01-02-2009, 10:24 AM
shows only 6 wires
GRN-POWER IN
IN LINE WITH BLK
WHT-OFF
ORN-ON
BLU-OFF
Thats interesting, thanks for sharing 12voltguy!
Looks like they changed it up quite a bit. On all the previous 5 pin Warns I have looked at White=power, Brown=Ground and Black=Winch out
Wish they would have kept it the same. Oh well, gues that would have been too easy
WTF_LOL is offline
post #13 of 29 Old 01-02-2009, 10:32 AM
easy to find ground with ohm meter
power in/out use a test light & habd remote
all warns except this PP are
brown=ground
green=in
black= out
only need to connect to these 3
older ones diod not even need the ground, the solenoids packs were grounded
any questions you think I can answer, just ask here, call pm email
I gota get back to work running 2-4 weeks behind
530.532.4529
post #14 of 29 Old 01-02-2009, 04:01 PM
lbh
lbh's Avatar
I will be ordering the 12 volt setup.
2007 JK
lbh is offline
post #15 of 29 Old 01-03-2009, 06:42 AM
John L's Avatar
shows only 6 wires
GRN-POWER IN
IN LINE WITH BLK
WHT-OFF
ORN-ON
BLU-OFF
You guys are right of course, I was working off a fuzzy memory. 6 pins it is. the other control on the remote is the air on/off switch.
And yes, the remote has the overheat led in it.
I can't tell what color the wires are in the remote, it's sealed up tight, no external screws, plug molded on. I still need to pull the winch out and take it apart to get to the wiring, but I have something to go off now, thanks!!!
/jl
John L is offline
post #16 of 29 Old 01-28-2009, 10:20 AM
nightmare73's Avatar
Are you also running a light in the dash to let you know if you over heat the winch?
nightmare73 is offline
post #17 of 29 Old 01-28-2009, 10:36 AM
if you are asking me, yes my ti panels have 2 lights
a LED tipped toggle under red cover to show armed, & a LED in the panel engraved "HOT" hooked to thremal sensor on winch
530.532.4529
post #18 of 29 Old 01-30-2009, 08:24 AM
can you make it work with all the features of the powerplant??
like on/off switch for the compressor???
that would be awesome, i hate getting the remote out everytime, this would save some precious time for sure
jeepik is offline
post #19 of 29 Old 01-30-2009, 08:55 AM
I have had customers do that.
I just put an on/off switch in panel, engrave air or a red cover with air decal
Just need to poke around inside winch & find the wire that powers up in air position, I have diagram to help.
530.532.4529
post #20 of 29 Old 01-30-2009, 09:57 AM
Dr.Dirty's Avatar
Feedback: 21 reviews
i want to do this for my warn m8000 anyone have the wiring for that one
www.jeepasylum.com
Dr.Dirty is offline
post #21 of 29 Old 01-30-2009, 10:12 AM
EMAIL ME
I thought I made it clear I DO THIS FOR A LIVING
But will email you a wire sheet FREE
530.532.4529
post #22 of 29 Old 01-30-2009, 10:23 AM
Administrator
HITMONEY's Avatar
I like this!
I just ordered the new Mile Marker V10 and Moose is getting my 9.5ti
A wireless controller would be an easier solution... but in cab controls are just cooler.
°lllll°
Facebook Page
YouTube Channel
HITMONEY is offline
post #23 of 29 Old 01-30-2009, 03:11 PM
Red Sunrise=Not Pretty
bfj aka tambil's Avatar
EMAIL ME
I had to LOL on that one...
You are definitely the one I will buy my switch from.!
Soon btw.
Proud to be an American
Shamed of our government
Native Floridian = MUD
bfj aka tambil is offline
post #24 of 29 Old 01-30-2009, 04:41 PM
John L's Avatar
I'm in the process of doing full function cab controls for the Powerplant, the 12volt guy is helping out. I'm still waiting on one part, it was re-routed because of the ice storm.
I'll do a full write-up on it.
/jl
John L is offline
post #25 of 29 Old 02-22-2009, 06:33 AM
07_Rubi's Avatar
pic under my name
love that switch panel...would love one just like it. can you send me a pm about pricing?
H3 Lux with Adventure Package
Gone but not forgotten:
2009 Black Rubicon Unlimited
2007 Silver Rubicon Unlimited
07_Rubi is offline
