6 Speed manual shifting problems... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 29 Old 11-18-2008, 12:57 PM Thread Starter
Has anyone had problems shifting from 1st to 2nd....I've tried shifting at different RPM's, speeds etc. it's a 50/50 chance that it will shift smoothly, the other gears are fine. Any thoughts????
Retrocouple is offline
post #2 of 29 Old 11-18-2008, 01:00 PM
Openly Hostile
Still under warranty? I'd take it to the dealer. Mine likes to pop out of third after a shift from time to time, pisses me off.
Jason
SDMF is offline
post #3 of 29 Old 11-18-2008, 06:03 PM
USAntigoon's Avatar
First and second have triple cone synchronizers, hence they are more complex and more prone to have alignment issues resulting in hard shift....In some cases the "hard" shift might disappear after a while (5.000 miles)....
I has to be stated that with triple cones, one has to shift quite fast.. don't go too slow, as this will allow the input shaft to coast down too much..and makes the synchro to work much harder..
USAntigoon
USAntigoon is offline
post #4 of 29 Old 11-18-2008, 09:34 PM
TEEJ's Avatar
Talking
My 6 shooter works pretty good, except its a little reticent about going into REVERSE....the forward gears are smooth as butter.
- TEEJ
2008 JK 4 Dr X. 5 Speed, LSD, JKS QD, 3.73 Diffs. Husky Liners and Daystar Hood Wranglers. Pine Stripes.
TEEJ is offline
post #5 of 29 Old 11-18-2008, 09:48 PM
Broncojohn's Avatar
Ditto. Third can pop out on occasion, but all others smooth as silk.
Broncojohn is offline
post #6 of 29 Old 11-18-2008, 09:55 PM
Eugene's Avatar
me too!
Eugene is offline
post #7 of 29 Old 11-19-2008, 01:03 PM
LSM
LSM's Avatar
I have ~9000 miles and I have the issue where the shift from first to second sometimes catches, it won't go in smooth, generally when it is cold but not all the time. I have no issues with 3 and above or reverse.
Should I be going back to the dealer??
ME
08 Rubicon Unlimited / জীপ্ Green / 6 Speed..
Mopar offroad bumper
Winch
Raider Evap Skid plate
Some mods to the bumper
It has started....
LSM is offline
post #8 of 29 Old 11-29-2008, 08:53 PM
JKrazed's Avatar
Feedback: 13 reviews
Copy that...
PROUD to be an
JKrazed is offline
post #9 of 29 Old 12-10-2008, 02:37 PM
qf4phlyer's Avatar
There is also an inner shift boot, that can cause difficult shifts, especially when it's cold.
08 Wrangler X DETN8R Yellow Rough Country 2.5" progressive rate coil lift, 2.2 shocks. 1.25" body lift, disco's,and steering stabilizer. Benchmark EVAP skid. TeraFlex front bumper with shackles. A.C.E. Rock Rails. 35x12.5x15 BFG AT's on MB72 wheels.Cobra 75 on a Firestik. Arizona Rocky Road antenna mount. Ward bug shield, DayStar hood wranglers & upper dash panel. Qtech arm rest.
2002 Wrangler Sahara RIP
1979 CJ 7 258 RIP
1975 Cherokee S 401 RIP
qf4phlyer is offline
post #10 of 29 Old 12-10-2008, 03:00 PM
kerryp's Avatar
One thing I learned many years ago is in order to make your shift into reverse easier, if you shift into say first gear first and them over to reverse it slides right in....became second nature to me always worked well. Course when I bought this jeep, it was my first auto in 20 some odd years and I miss my standard...unless I'm sittin in traffic
kerryp is offline
post #11 of 29 Old 12-10-2008, 04:09 PM
terrahawk's Avatar
Gettin' into reverse is like rowing a damn boat!
terrahawk is offline
post #12 of 29 Old 12-10-2008, 04:20 PM
Swinge86's Avatar
Yes, i've had a lot of problems with 1st and 2nd. Took mine to the dealer and take a guess what they said..... 'We can't duplicate the problem'. Well of course you can't! You probably drove it for about one mile and didn't do any driving with it at all! pisses me off
'08 Silver JKU - Grace
“We often miss opportunity because it's dressed in overalls and looks like work”
― Thomas A. Edison
Swinge86 is offline
post #13 of 29 Old 12-10-2008, 04:40 PM
beagsjeep's Avatar
a little bit when cold..
beagsjeep is offline
post #14 of 29 Old 01-09-2009, 08:34 PM
I had no problem until I read this post the first time! lst to 2nd IS a bit notchy. And reverse can be a treasure hunt. Still better than an H Farmall tho.
cowboy49 is offline
post #15 of 29 Old 01-09-2009, 08:54 PM
StubEXrube's Avatar
Wow- Learned to drive on a Farmall Super C. What a trip down memory lane. Thanks!
StubEXrube is offline
post #16 of 29 Old 12-17-2009, 01:56 PM
I have the same mileage, the same problem, and the same question... Should I return to the dealer?? I haven't checked the fine print, but I would assume this would be covered by my unlimited mileage lifetime powertrain warranty. I haven't added a lift or the 35s yet, but that was definitely in the plan. Anyone know if Jeep will honor warranties on powertrain if the suspension has been modified?
absolut506 is offline
post #17 of 29 Old 12-17-2009, 02:25 PM
Liquor's Avatar
auto or manual??
ive had 0 issues on my 6sp.
i read more complaints with 6sp with a body lift.
• Your Jeep and Gaming Social Network
2012 Sponsors:
Magazine Feature:
Liquor is offline
post #18 of 29 Old 12-17-2009, 02:36 PM
scottrock's Avatar
ditto on the no issue. I gotta hunt for 5th once and awhile when I'm not paying 100% attention.
scottrock is offline
post #19 of 29 Old 12-17-2009, 07:32 PM
Originally Posted by Liquor View Post
auto or manual??
it's the 6sp. I don't really mind it being a little "notchy" during the 1-2 shift, I'm just wondering if it's going to keep getting worse, or if there are any known issues that the dealer would be aware of?
post #20 of 29 Old 12-17-2009, 08:00 PM
NE Wrangling's Avatar
mine pops out of 1st and 3rd on occassion but I'm convinced it's the boot getting caught on the daystar panel not allowing it to fully engage. If I focus on shifting it never happens but when I'm in stop and go traffic it happens since I loose my mind on idiot drivers and don't pay attention.
jk-forum, jk forum, jkforum, jeep jk wrangler, jk-forum.com, jeepforum, jk-board.com, wayoflife, 2007 jk, 2008 jk, 2009 jk, 2010 jk, jk, jk wrangler
Never argue with an idiot, they will bring you down to their level then beat you with experience.[/SIZE][/B]
NE Wrangling is offline
post #21 of 29 Old 12-17-2009, 08:02 PM
scottrock's Avatar
How many miles? Mine was kinda tight when brand new but has loosened up considerably after 50k.
post #22 of 29 Old 12-18-2009, 08:06 AM
BadAzGirlsDriveBadAzToyz's Avatar
all mine are smooth except 3rd, which is odd. like someone else said, kinda notchy going in, some resistance. i really have to have the clutch floored otherwise, it'll grind. i hate to admit it but i've ground it three times.
BadAzGirlsDriveBadAzToyz is offline
post #23 of 29 Old 12-18-2009, 08:10 AM
riverzendz's Avatar
The colder it gets the "clunkier" 1st to 2nd is. Not really a big deal, just have to go easy.
Once it warms up it's fine.
riverzendz is offline
post #24 of 29 Old 12-18-2009, 08:22 AM
.:eMETAL:.'s Avatar
no problem here at all.
.:eMETAL:. is offline
post #25 of 29 Old 12-19-2009, 02:07 PM
Ive had mine pop out of 1st and 3rd on many occasions. My problem was when I purchased(used) the shifter inner and outer boots had been torn. I replaced the outer boot with the bezel from jeep for 35.00. I did not change the inner and sometimes it gets out of alignment. You can actual feel when its not sitting right. It feels like resistance against the shifter. I take and slap mine around abit in the neutral position and it realigns. Then I can shift without issues. You can actual feel it if you put it in first and slightly move your hand off the shifter and behind it towards second gear position. BE CAREFUL that you dont have your fingers there. Use only like the palm of your hand. It will smack the crap out of your hand if it flies out. BUt try it and notice that as you let the clutch out and pressure is applied that the shifter does naturally feel like its moving towards second. Thats just the torque on the tranny. When the boot is in the correct location it will just barely move. When its not it will pop out and sound and feel like you just got rearended. Scared the crap out of me the first time. I was about to jump out and have some words with someone at a stop sign. Then I realized I was the only vehicle at the stop sign. Good luck hope the info helps.
Hotwire is offline
