Aftermarket Power Windows / Locks - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 01-31-2010, 06:11 PM Thread Starter
I tried searching the forum for any recommendations/comments on installing aftermarket (or MOPAR) power windows and locks (4 door), but I couldn't find anything (sorry if this is a duplicate thread). Any comments or links would be appreciated.
HurricaneBob is offline
post #2 of 7 Old 02-01-2010, 01:22 PM
We are interested in the same thing. I want original style jeep key and not an aftermarket keyfob. I did a couple hours of research and it is possible, but not cheap. None of my local dealers will even give me a quote to do it, although they would order all the parts and then charge me for time spent installing them. I have not signed up for it. Please post if you find anything.
Probably best path is to find donor doors (dont forget the tailgate) from wrecked jeep with power windows/locks. That gets you most of the way, less some harness and a control box. If the donor doors are not damaged, you could probably sell the shells with your old manual parts after you strip the stuff you need.
Chris
chrisholm is offline
post #3 of 7 Old 02-01-2010, 03:59 PM Thread Starter
I've found a couple aftermarket kits, but I'm not sure how they look installed, so I'm hesitant to use them... I like the OEM look. Will let you know if I find anything.
post #4 of 7 Old 02-01-2010, 04:43 PM
Hey Guys
I've been reading threads on power upgrades for my X for a while. Most of what I have read sudgests that you should stay with MOPAR parts for this upgrade. One person tried to use an after-market power window kit with NO success. Said he had to make several mods just to get the equipment to fit. And then it did not function well. Factory EQ, may be more expensive. But fit and finish my be worth the extra $$$.
"The Green Monster"
2007 2 Door X Jeep Green with Freedom Top
16" Painted Aluminum Mopar Wheels
Grab Bar Mod on front bumper
130w KC Daylighter Driving Beams on grab bar
130w KC Daylighter Long Range Beams
on
Smittybuilt Windshield Brackets
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline
post #5 of 7 Old 02-04-2010, 01:25 PM Thread Starter
I found this thread on another forum, although I don't like the way the switches look.
http://www.jk-forum.com/showthread.p...=power+windows
post #6 of 7 Old 02-06-2010, 11:13 PM
rbuckenmeyer's Avatar
I used to install aftermarket electrical acc, including windows. My suggestion, don't use aftermarket power windows. The kits probably wouldn't work (fit issues, as stated above) and they never really work very well. They are very problem prone too. So, if u can get MOPAR parts, go for it, otherwise, I wouldn't bother.
rbuckenmeyer is offline
post #7 of 7 Old 02-06-2010, 11:46 PM
Mr.RonGilbert's Avatar
http://www.jk-forumSUCKSBALLS.com/showthread.php?t=33231&highlight=power+windows
Wow.... that other forum sucks balls.
(IBTM)
I have thought about it too but it sounds like more trouble than it is worth. Let us know how it goes if you do it.
Mr.RonGilbert is offline
